going to get my wade regrind soon couple of questions for the ppl out there with a regrind cam if ur on a bit of a buget is is essential to have hd valve springs? im only using the new wade cam the 60somthing(not ot good with numbers) but i no its only mild bcos the ecu
also were is the best place to get these shims which i know all about how many do i need how much are they car ef gli i6
AU FAIRLAINE GHIA TICKFORD I6, KINGS SL/KYB ALL ROUND, RED BACK EXHAUST, G220 RIMS |
no springs needed,,shims you can get from ford and you'll need 12
2000 AU Wagon |
cheers for that mate what do 12 shims cost is there differant sizes?
i think there about $3 to $4 dollars and you need the 1.9mm ones from what everybody said.
i also think you add them to the one already in,so you end up with two,,have to double check on that one.
2000 AU Wagon |
cheers mate
can anyone verifly what naughty has said?
Yes, he's spot on.
Brent |
just take one of ur shime too ford then thay can get the right ones saves time having too go bk coz ther the wrong ones :P plus ther 5$ each
Fairmont6
gettin a bit off the subject here but i am waiting for my 1636 wade cam, i think its called, am i gonna benefit at all from an xr6 ecu???
Last warning
or you could buy a rocker rack from a wrecker and pull the shims out of that.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
thats wut we ended up doing :P
#11 | |||
overdriven
#12 | |||
Two > One
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
#13 | ||
ok thanks so what size do i need it i get the shims or washers?
#14 | ||
bumpyy
#15 | ||
Two > One
remove one of your shims and go and match it up for similar (slightly smaller) washers.
#16 | |||
I was just looking through some old Wade specs sheets from when I was doing the original E-series cam testing for them...
One I didn't try was the 977B duration is 206@.050" lift is .512" phase angle is 111 (which of course can be changed to be a bit more mild like 113) I reckon this would be cracker, but it will require aftermarker springs. Dave.
#17 | ||
Two > One
yes the 977b is basicaly a highlift 1004. Being ground on a higher lift, the 0.050 timing is also increased slightly to 206deg and the tightish LSA may hamper a stock Auto ECU. But if you opt for a 113LSA this cam should be a cracker in an auto.
I've installed 3 Wade cams, 1004/110, 1386c and 1521a, all are VERY VERY diffrent.
