Old 03-12-2012, 10:11 PM   #1
tim_pato
tim_pato's Avatar
Default throttle sensor, does it control idle? only thing i havnt replaced
what else controls idol? ive changed plugs leads coil o2 scensor keep winding out idol screw.(dedicated gas zavoli reg) dies when pulling up.
tim_pato is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2012, 06:16 AM   #2
wrexed03
Default Re: throttle sensor, does it control idle? only thing i havnt replaced
Check with your lpg guy. You may need a balance pipe fitted.
Goes on a fitting on the lpg converter and and the airbox from what i recall.
wrexed03 is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2012, 07:48 AM   #3
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
have you been adjusting the screw on the throttle body ?
or one of the 2x adjuster screws on the convertor ?
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2012, 01:25 PM   #4
tim_pato
tim_pato's Avatar
yep there is 1 there, caused a reallt bad flat spot when it was hooked into air box.
Old 04-12-2012, 01:31 PM   #5
tim_pato
tim_pato's Avatar
the smaller 1 on the reg. i took it too a gas mech who said he couldnr tune it because he had never seen. i havnt had a chance to take ir elsewhere.
Old 04-12-2012, 01:36 PM   #6
tim_pato
tim_pato's Avatar
it idles fine, a bit high now. just dies occaisanallt when say pullinf up at the lights
Old 06-12-2012, 05:54 AM   #7
Lajon
my lane does the same thing at lights occasionally and i'm running straight petrol
Lajon is offline   Reply With Quote Multi-Quote with this Post
