Old 05-12-2012, 02:42 PM   #1
nathanashton
Default "Global" Window Opening
Hi All,
Recently picked up a 2012 Focus MKII Trend .Great car by the way. The manual refers to being able to open the windows using the Key Fob. Various sites on the net state the same. I cant seeem to get it to work and wonder if it is only for higher models.
Anyone have any experience or knowledge on this?
nathanashton is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2012, 03:17 PM   #2
BrisVegas
Noobie
Default Re: "Global" Window Opening
not sure on the current model, but with my old LS Focus you held down the unlock button on the keyfob for about 3-4 seconds and the windows would all come down.
BrisVegas
WS Fiesta Zetec 3dr
NM Pajero TD LWB
LS Focus Zetec 5dr - gone
WS Fiesta Zetec 5dr - gone
BrisVegas is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2012, 03:37 PM   #3
nathanashton
Thanks. Have tried that numerous times. Also done the procedure in the manual to 'set' the window limits, which is basically windows down, then press down for a while, windows up, press up for a while.
Nothing seems to make it work. Has me a bit puzzled.
Old 05-12-2012, 06:26 PM   #4
marg99
my MY08 LT focus has global opening. You hold the "unlock" symbol on the remote control down for about 3-4 seconds and all four windows come down great on hot days to open the car up. My manual says "where fitted which suggest some variations may not have it installed
Old 05-12-2012, 06:46 PM   #5
DJM83
Barra Turbo > V8
DJM83's Avatar
If it is the same as LV when putting them down you need to press once and hold, they will go down.
To go up i need to press once, then press and hold.
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
Old 05-12-2012, 07:03 PM   #6
Mercury 8
Mercury 8's Avatar
Just tried our LW,press and hold unlock to have all go down and press and hold lock to all go up.
Mercury 8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2012, 09:02 PM   #7
nathanashton
Mmmm...I must be thick then as I cant get it to work
Old 05-12-2012, 10:25 PM   #8
Redrum
Force Fed Fords
Redrum's Avatar
Now that this has been mentioned I remember my sales man at Binks Ford explaining it to me....
2021 Focus ST-3 Mountune Enhanced
Redrum is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2012, 10:30 PM   #9
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
If it's not working by simply pressing and holding either the unlock button on the remote to open the windows or the same process to close them via the lock button on the remote then there is obviously something wrong. It's possible that there is a setting which needs to be activated on yours, this should be able to be done quite simply via the OBD port using a suitable reader. It's under warranty so I would suggest taking to the dealer and having it checked or as it's not really urgent, mention it at your next service
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2012, 04:36 AM   #10
AG3
AG3's Avatar
Originally Posted by nathanashton View Post
Hi All,
Have you tried resetting the memory of your power windows?
I found something on this forum (from owners of the current Focus): http://www.fordownersclub.com/forums...touch-windows/
Hi, it isn't quite the same process to program the windows on the 2011 Focus as the previous models:
1. Lift and hold the switch until the
window is fully closed.
2. Release the switch.
3. Lift the switch again for one more
second.
4. Push and hold the switch until the
window is fully open.
5. Release the switch.
6. Lift and hold the switch until the
7. Open the window and try to close it
automatically.
8. Reset and repeat procedure if the
window does not close automatically.
Chris
Chris
just picked up your reply up.
all windows now programed and work on one touch and global open/close
many thanks much appreciated
If you are still not sure, you might want to research more on resetting procedures for your power window or just have it checked at your Ford dealer/service center.
I followed a similar procedure (may not have been exact) before for my 2006 Focus after I changed the battery, it worked.
AG3 is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2012, 11:29 AM   #11
nathanashton
Thanks. I will get Ford to check it at the first service. I have tried the above procedure, and variants of it with no success. Cheers
Old 06-12-2012, 12:33 PM   #12
Marquis
HUGE MEMBER
Marquis's Avatar
Cool Re: "Global" Window Opening
Thanks for the heads up. I called the Mrs to give it a crack. Works great. Orsm for Qld heat. Auto close aswell. I should read the book. I wonder what else the little terror does.
I would not pee on a Holden if it were on fire. I would take pics and post for your pleasure
My cruiser. 1979 Zh Marquis. "T" code 351.
My garage queen :(. 1980 TF Cortina Ghia Wagon. 4.1.
My dog. 2011 Sierra
My Daily. 2012 ZH (lol) OUTLANDER xls. 4WD CVT. Sapphire blue
Wanted
Borg Warner Lsd or centre. 25 spline
Marquis is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2012, 04:44 PM   #13
sirlc6
It's only available on sports and titanium in lw2
sirlc6 is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2012, 05:54 PM   #14
Mercury 8
Mercury 8's Avatar
That would explain Nathan's problem then. Thanks.
Old 06-12-2012, 05:58 PM   #15
Marquis
HUGE MEMBER
Marquis's Avatar
Mine listed below is a base model Ambiante and it works
My dog. 2011 Sierra
Wanted
Old 06-12-2012, 06:07 PM   #16
sirlc6
Mk1 or mk2 you can tell by the indicator stalk mk1 has it on the left mk2 has it on the right . Mk1 will have global opening and global closing in ambiente mk2 doesn't.
Cheers Paul
Old 06-12-2012, 06:27 PM   #17
Marquis
HUGE MEMBER
Marquis's Avatar
Must be a 1 bud.
My dog. 2011 Sierra
Wanted
Old 07-12-2012, 10:05 AM   #18
nathanashton
Thanks for the info. At least I know it's not something Im doing wrong!
Shame it isnt included though as it does seem like a handy feature, especially in QLD
