Old 20-12-2005, 05:50 PM   #1
CruizinEB
Question Box filler,Whats the best to use????
Box filler,Whats the best to use in speaker boxes???
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 05:52 PM   #2
wang peterson
this should be in the audio section.
Old 20-12-2005, 05:57 PM   #3
darnoldrs
The most cost efective is to go and buy some cheepy "hollowfill" pillows, pull all the stuffing out of them and use that. works very well and is very simalar to the proper stuff.
Pillows= about $4.00
Accustic filler= about $25.00+ for the equililant amount.
David
RIP, EL series 1 XR8, Manual, 3.45 LSD, 347 Stroker, Big bore Pacemakers, and K&N. 180.2 rwKw
Replacment,
FG MK1 FPV GT-P, Manual, 5.4, Stock Standard everything.
darnoldrs is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 06:00 PM   #4
CruizinEB
mmmmm i already have the Acoustic filler in them, Whats it for BTW, Better sound??
Old 20-12-2005, 10:27 PM   #5
mcflux
mcflux's Avatar
Stops the boxes from vibrating. Turns untzz untzz into doof doof.
Old 20-12-2005, 10:31 PM   #6
ten[A]cio[U]s
ten[A]cio[U]s's Avatar
I used Sound Deadener (Dynamat). It stopped all rattles for me and made a really nice crisp bass note.
ten[A]cio[U]s is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 10:34 PM   #7
need psi
slow & low EA Ghia
need psi's Avatar
spot light sells some stuff which is pretty much a inner pillow liner, exactly the same as the sub box liner, its about 10bux iirc.
Ehab
Ea Fairmont Ghia 1988
need psi is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 12:27 AM   #8
sphell
sphell's Avatar
the proper stuff is called Dacron. You can pretty much use anything like soft toy stuffing or whatever. Just visit Spotlight they'll have something. Personally I think it's like many things in car audio that I'd call a "1% factor". That is, it basically does jack to the sound. I'd put it in the same category as capacitors.
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 02:58 AM   #9
TuMor
its not a!
TuMor's Avatar
bwahaaahaaaa
-93'ED XR8-
5-spd
Charcoal Black
ohh yeeah
TuMor is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 03:07 AM   #10
CruizinEB
i think it Turns doof doof into untzz untzz
Old 21-12-2005, 06:27 AM   #11
efgiar
rofl copter
efgiar's Avatar
i think ull find that it gives the sub woofer the impression of a bigger box, and itll give u a little bit more bass. wont stop any vibration at all, your boot will sound like your mums vibrator on a tin roof, but you get that
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 06:30 AM   #12
efgiar
rofl copter
efgiar's Avatar
sphell, if you think capacitors do jack, try and run an amp more powerful then 300 watts, and see how your lights dim when the bass go off, i gaurentee you capacitors give you a LOUDER and better sound if you have your lights dimming,
<3 capacitors
die sphell
GQ patrol.
thats all
Old 21-12-2005, 07:26 AM   #13
darnoldrs
<3 capacitors
die sphell
And you dont get clipping to the signal which leads to dead subs.
The only way you will get a decient bass note from a sub is
1. Build a box designed for that paticular sub and
2. Power is propperly.
As stated aboce the filler only gives the sub the impression of a slightly larger box and helps with a little "ringing". your box should be totaly sealed, air tight with the excepton of the port if you have one. Enjoy. David
Replacment,
Old 21-12-2005, 02:47 PM   #14
toby123
Boosted TQE FTW
<3 capacitors
die sphell
Boot mounted battery's are a way better option and dont work out all that more expensive. My old audio setup in my old monty' was 2,500wrms with no capacitors just small drycell battery..
Daily Driver: 08' ford ranger
Project: EF Falcon Turbo... Not long till back on the road.....
toby123 is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 04:49 PM   #15
Walkinshaw
Two > One
Walkinshaw's Avatar
The filling of sub boxes with dacron is an old trick used to try and fool the speaker into thinking (and reacting) like it is in a much bigger box than it actualy is. Its been 4 or 5 yrs since ive been into the audio caper but like Sphel has said its a 1% thing for final tuning. It is NOT to be used to stop boxes ratteling. If your box rattles its crap, throw it out.
My two cents on capacitors. if you need one, your electrical system is a JOKE! I had over 2400wrms to subs and 1600wrms to front speakers at one stage, and not one capacitor. My lights didnt dim either
Old 21-12-2005, 06:20 PM   #16
mcflux
mcflux's Avatar
woah! Hold it... you got it all wrong at "I think"
Old 21-12-2005, 06:45 PM   #17
CruizinEB
no i got it right, i think it reduces the movement of the cone
