Old 23-12-2005, 02:20 PM   #1
old_mate
Smash the Boost
old_mate's Avatar
Default Found something strange...
..dunno if its meant to be like this or not, but im spending some time under the car doing bits and bobs, and while changinging my radius rod bushes I have noticed on the passenger side I cant get a ring end spanner onto the nut cos the k frame is in the way. On the drivers side there is half an inch clearance. is something bent or is that the way it is?
Also been down to repco to score a pair of bushes for where the radius rod meets the lower control arm, he couldnt find a part number, anyone know it? Trying to get nolathane items
Am also learning wheel alignments done by sight arent often correct lol.
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 04:39 PM   #2
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
They should be the same distance apart unfortunately :(
K-Frames bend fairly easily with a gutter impact, along with the radius rod, and quite often the LCA. The motor needs to be lifted, or held in place to change the K-frame too.
If both front wheels have the same amount of castor, I wouldn't worry about it too much myself.
Old 23-12-2005, 05:51 PM   #3
old_mate
Smash the Boost
old_mate's Avatar
its actually what looks to be the lower part of the radiator support panel, although nothing looks bent and its all still bolted in? it couldnt be where the radius rod bolts into, that'd mean the chassis was bent.
something is amiss
i couldnt even get the front half of the radius rod bush onto the radius rod cos there was no clearance. had to drop the lower control arm yet again, raise it most of the way up with a jack, then put the front half of the bush/nut on a couple of turns, then bolt it all back up. this isnt making me happy
1971 Fairmont Sedan
1974 SWB F100
Old 23-12-2005, 06:39 PM   #4
old_mate
Smash the Boost
old_mate's Avatar
mmm
just had a look under a mates EB and its the same there as well
good on nolathane for letting everyone know their new radius rod bushes dont fit once your rod is back in
1971 Fairmont Sedan
1974 SWB F100
Old 24-12-2005, 09:56 AM   #5
NZ
NZ's Avatar
Stick to planes mate ;)
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2005, 07:59 PM   #6
old_mate
Smash the Boost
old_mate's Avatar
haha thanks Karl
Everything is back together ok...and surprise surprise no rattles or clunks! Wheel alignment however is shocking...didnt realise there is about 6 shims either side (for the camber kit)
How anyone can get close without a camber kit has me stuffed
1971 Fairmont Sedan
1974 SWB F100
Old 25-12-2005, 05:51 PM   #7
BI6TIM
SnortPerformance.com
The K-frame should be like that, i don't know why thats just the way they are. As for camber kits, you can get it pretty close if you've done it '15 000' times, thats what you get for working at pedders i supose.
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2005, 05:55 PM   #8
Walkinshaw
Two > One
Walkinshaw's Avatar
You poor poor person
