25-12-2005, 11:37 PM | #1 | ||
I am hoping someone can give me some advice here.
I have a 1988 LTD and need to do a tranmission exchange. I have an EA with a good transmission and a poor motor, I am intending to take the transmission out of the falcon and put it into the LTD. They are both three speeds. Is there any thing that I should know before I get started? What parts, seals, gasklets etc should I get first? What problems am I likely to have? Any advice from anyone who has replaced their transmission before would be appreciated. cheers Roy |
26-12-2005, 01:40 AM | #2 | ||
Two > One
The swap will be quite easy.
Parts: Pan gasket and filter for the new trans 15L of Dextron3 Problems: none really, very easy swap Also, if your engine rear main seal leaks this is the perfect oppourtunity to fix it.
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
26-12-2005, 09:32 AM | #3 | ||
Plus while the transmission is out put in a brass welch plug .
26-12-2005, 03:57 PM | #4 | ||
Oops, I slipped....
It wouldn't hurt to replace the front trans seal while its out. They can harden if they haven't been used for a while.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
26-12-2005, 04:35 PM | #5 | ||
windsor user
the only thing that might be an issue is if the EA is CFI. (centerpoint injection)
the CFi cars had a different kickdown cable to the multi point cars.... |
