Old 06-03-2013, 02:31 PM   #1
TK-421
Default AU 2 Tail lights into AU 1.
Will series 2 Fairmont tail lights function in my AU 1 XR8? Are they wired the same?
Cheers.
TK-421 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2013, 03:47 PM   #2
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Default Re: AU 2 Tail lights into AU 1.
Yes and No
The lights fit but the plugs changed, so you can solder/join the wires or get an adapter plug.
If you buy genuine I think it comes with it.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2013, 05:30 PM   #3
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
FYI iv done this 2 times just plugs in issue... no cutting needed... (sadan)
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2013, 06:07 PM   #4
TK-421
Ok, thanks for the replies.
Old 07-03-2013, 10:12 AM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
exactly the same, only difference was clear lenses on the indicators for the series 2
only change you will need to make is changing your indicator globes to orange ones
Old 07-03-2013, 12:44 PM   #6
TK-421
Thanks for the reply Mr Hardware.
What is the most desirable tail lights in the series 2 - 3 range? or are they all the same.
Old 07-03-2013, 12:54 PM   #7
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Series 2 and 3 are the same...
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
