Old 09-01-2006, 06:27 PM   #1
KOUPE76
OLD SKOOL BABY
KOUPE76's Avatar
Default Tickford Premium Brakes.
Just wondering your opinions are on them as I am looking at buying a set, I remember Sylox and Bucky having some issues with a loose rotor or something like that and what's the best brake pads for them.
Thanks All,
Mick
XB Sedan - Trick Mansweto built 351 3V Alloy Headed Cleveland,Demon Carby ontop of CHI Hi Rise Manifold - 600HP
83 F100 XLT - 351 Cleveland C6 Auto wrapped in Black snake skin vinyl, daily tow rig.
1976 XB GS COUPE (waiting to start the rebuild)
KOUPE76 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 06:29 PM   #2
parawolf
beep beep
Have a look at one of the guys on the forums - he is selling off a set of 4 piston AP Racing brakes with 330mm discs $1800 for calipers, hardware and rotors (2nd hand equipment). He seems keen to sell so perhaps you could do better again?
Nothing to see here, move along, move along...
parawolf is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 06:35 PM   #3
LG
LG's Avatar
Tickford Brakes are great. Great improvement. When I got mine done, I wasn't quite expecting to spend so much. If i had of known new discs + pads + caliper costs + fitting would of charged that much. I would of gone straight to a PBR Setup. Although, done now... I'm very happy with them. Heaps of bite. Don't go the Bendix Ultimates or Advance. Great pad, but way to much dust. Sylox is using EBC Green Stuff Pads (apparantely really good).
If you can get the Tickford setup cheap, and even the rotors and pads, then it'll be ok. But if you have to buy new pads and rotors. Expect an easy $800+.
The problem was a loose caliper. In time, the locator pin becomes worn, and there is some movement. John can send you out a simple $50 kit, which will fix this. Bucky still had some slight movement, and knocking, and further fixed it another way.
That AP Racing Setup looks nice, although remember he is not selling 4. He is selling a front pair (2) of 4 piston calipers. Which will just be all wrong, when thrown on to the car with Stock rear brakes.
LG
AUIII Falcon Forte, with SIX Appeal
LG is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 06:37 PM   #4
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
Go the Ap's, or Brembos, Alcon or any of the other aftermarket premium gear.
I'm guessing that yoou're referring to the Ford twin piston front, single piston/ slotted rotors by PBR.... and trust me they have not got nothen on any of the above.
I discovered the joys of stopping as hard as I can go and oh mother, it is a revalation. Best mod ( and it should have been the first mod) I made to my XR.
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 06:41 PM   #5
LG
LG's Avatar
I'm not quite sure, but I thought the PBR's did come in a 4 piston caliper. What did Falkeen get for his ute?
They are around the $2k mark, with everything. New rotors, pads, lines, calipers.
Old 09-01-2006, 06:53 PM   #6
tex
Broken
tex's Avatar
Im guessing that for those dollars, the kit is twin piston front, single piston rears. A good economical set up.
4 piston stuff usually starts at a bit over 3 K for fronts only, including braided lines and performance pads.
The Scud GT
Old 09-01-2006, 07:22 PM   #7
parawolf
beep beep
The PBR performance kit is a twin piston "C6" model caliper
You don't need to upgrade the rear caliper or disc. About the the only thing required would be a pad change and if you like grooved rotors.
Old 10-01-2006, 12:08 AM   #8
12
Silhouette AU1 TS50.
12's Avatar
I'm with parawolf on this. Go for the 4 piston AP set for sale. It will make a huge difference over the 2 piston Tickford set up. Most of the braking is done by the fronts, the rears will not be all wrong, will be fine.
I'd take a 4 piston front caliper over a 2 piston set up anyday. I don't understand why people upgrade their already 2 piston front set up for another aftermarket 2 piston set up, even if it comes with slightly larger diameter rotors. Waste of money. If you going to do something, do it proper.. get a 4 piston front caliper set up. For a little extra, it is a HUGE difference as opposed to a small difference.
The guy selling the 4 piston AP set up is in Melbourne, and if it is infact the Cebco set up, they're also in Melbourne if you need help fitting them up. $1800 ono is not a bad price, I say get it BLUPRNT XR8.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 02:08 AM   #9
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
Just watch the AP racing brakes and your wheels, a lot of aftermarket wheels will not fit over them as the spokes foul on the caliper, forget any wheels with a dish to it. As for the PBR setup, great brakes at a great price. I can not get them to fade on the road and my trans overheated before my brakes faded out on the track. Sure the 4 and 6 pot brakes are better but who really gets to use them to their full potential on the road? I would rather put the extra money elsewhere thanks.
Growing old is compulsory, growing up is optional!
geckoGT is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 09:35 AM   #10
jspec_sti
Agree with gecko, the PBR setup is great. The stopping power compared to the standard setup is like chalk and cheese. The first (and only) mod to my XR8 so far.
jspec_sti is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 09:39 AM   #11
parawolf
beep beep
Very true. However you have to check this with the PBR setup as well if you are also getting the 330mm rotors as they require a 17" minimum wheel.
Old 10-01-2006, 01:54 PM   #12
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Sylox has a Tickford T series seutup.
I have a similar setup on my ED, its the best money ive ever spent on my car.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
