Old 16-08-2005, 10:33 PM   #1
rebornafordman
Question Where did my heaters go?
My EA fairmont ghia's heaters have stopped working. Its got climate control, but when you crank the heat up nothing happens. HOWEVER one thing i did notice was that even when the temp was turned up to 32 or whatever it is it sounded like the air con compressor was still kicking in.
Perhaps the heaters are working but the air con is cooling the air?
Stupid little problems like these normally cost lots to fix so im leaving it up to you guys to help me out.
rebornafordman is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2005, 11:07 PM   #2
BuuBox
I had the same sort of problem, not entirely sorted yet either. My heater box was filled up with leaves and all sorts of shrubbery, so with a bit of a clean out, started working a hell of a lot better. Could be your blend door motor too though...
You can disconect the a/c compressor, follow the wiring and there should be a plug. See if that helps?
BuuBox is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2005, 12:29 AM   #3
Dezza
Parts bin special
Dezza's Avatar
Gotta love those EA Ghia heaters. I had a blocked heater core. It was putting out plenty of air, just not warm air... and a heater tap that only partially opened.... and to top it off a dodgy ambient temperature sensor (still need to go and check the wreckers). Hopefully that is the last of my heater troubles. Good luck with yours.
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2005, 11:47 AM   #4
CruizinEB
sounds like the A/C isn't Disingadgeing
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2005, 04:59 PM   #5
EA2BA
PM me if you want
EA2BA's Avatar
igntion on, press the floor and off button at the same time, tell me what error codes you get, if any.
Old 17-08-2005, 09:09 PM   #6
T_Terror
The Guy You Love To Hate
Where do i find the heaterbox and where could leaves n crap be coming in? I get a really stron smell of burning leaves and grey smoke starts shooting out sometimes when i get hte heater on full.
T_Terror is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 05:36 PM   #7
rebornafordman
ok dellboy999 ill give it a try.
Old 18-08-2005, 06:35 PM   #8
rebornafordman
ok code E2 came up, does that help?
Old 18-08-2005, 08:06 PM   #9
Paris Hilton
Custom User Title
Paris Hilton's Avatar
Blend Door Motor failure
Paris Hilton is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 09:06 PM   #10
-AL-
Knuckle Head
-AL-'s Avatar
T Terror, you're issue is likely build up of leaves on the Resistor coil. Up underneath the glove box(remove glovebox and its easy to sort out)
Couple of philips head screws later and you can hook all the leaves and crap out.
-AL- is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2013, 03:34 PM   #11
Default Re: Where did my heaters go?
Old post I know know but in case someone trawls this up looking for a solution for a similar problem note that Climate control does not have resistor pack fan speed controllers but has a computer controlled fan speed controller that is transistorised. But the leaves behind the controller do corode the transistors casing and cause fan speed issues.
Old 02-08-2013, 06:47 PM   #12
Guess_who
Reviving an old thread I know but it reflects the problem with my EA with climate control. I have replaced the climate control unit several times - the latest unit at least does seem to work ... but ...
I am having a similar problem to the OP in that when heating the AC compressor cycles on and off even when set to 32.
There are no error codes when I run the diagnostic test.
Guess_who is offline   Reply With Quote Multi-Quote with this Post
