Old 11-08-2013, 07:56 PM   #1
Travisty.123
Default AU S1 Cruise Control issue.
Hi guys, just having a spot of trouble with the cruise control in my AU, I twist the knob to activate the CC, lights up on dash as "Cruise" and then I press the middle steering wheel button to set it, which lights up as "Set" on the dash, but that is the most it does. From there, if I take my foot off of the acceleration, I'd just slow down to a complete stop. Doesn't matter what speed I'm doing.
I've done a bit of searching on these forums and another, found other issues, but none that are the same as mine. Brake fuse is intact, which is the most trouble shooting I've done thus far.
Any help is vastly appreciated.
Travisty.123 is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2013, 10:34 AM   #2
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Default Re: AU S1 Cruise Control issue.
Hi Travisty.
I had the same issue on my NL Fairlane, which run the exact same cruise unit. The only difference in the NL I did not have a 'Set' indidicator, meaning my problem could be a little different to what you are experiencing (symptoms where not exactly the same).
The problem that I found was that it was the override switch on the brake master cylinder. I replaced it and all was good. The only difference, is I do not know if the 'Set' indicator would come on if this switch was faulty.
It certainly was not expensive for you to try, I found a brand new one at my local Ford Wrecker.
Good luck with it,
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is online now   Reply With Quote Multi-Quote with this Post
Old 12-08-2013, 12:09 PM   #3
FGII-XR6
FGII-XR6's Avatar
the system is actually setting but not operating the accelerator so it won't be the over ride switch. you will find it is the actuator under the bonnet either the cable has come loose from the throttle body / broken or the motor in it isn't working
[SIGPIC][/SIGPIC]
Rides:
Old 13-08-2013, 10:37 PM   #4
Travisty.123
Thanks guys for the responses, I'll have a look tomorrow arv, just to be a little more dense, what exactly would I be looking for on the cable to the throttlebody?
Old 13-08-2013, 11:01 PM   #5
FGII-XR6
FGII-XR6's Avatar
if the cable is intact and not loose it will be an actuator fault
[SIGPIC][/SIGPIC]
Rides:
