Old 13-01-2006, 04:37 PM   #1
ozzie
Default eb & Nf V8's pinging
got these two cars and when you get hard on the accelaration at about 75-100kmh ( approx starting at 1500 till it get to 2300rpm) they PING!! ( particular on hot days.
I've put new plugs, new rotor and use good PULP..... whats going on
email : sam.ilardo@axa.com.au
Old 13-01-2006, 04:57 PM   #2
snypereb
[EBGLT]
snypereb's Avatar
Check your timing!
Is it advanced to much!
Thats a pretty good place where pinging starts!!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2006, 05:02 PM   #3
EDXR8
EDXR8's Avatar
Base timing is a good place to start, set it to the factory 30 degees (although with PULP you can probably go to 34-36 without too much trouble). The other thing to look at is your MAF sensor, especially if you have an aftermarket oiled air filter like a K&N etc. The sensor wires gradually become coated with dirt or oil from the airfilter causing the engine to run lean and ping. Best way to clean it is to remove the electronic module from the MAF body (you need security torx bits for that) and then spray the sensor wires with carby cleaner. If the dirt is baked on you can use a cotton bud covered soaked in carby cleaner to help remove it, just be carefull not to break the wires.
EDXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2006, 05:16 PM   #4
ozzie
Is the MAF Sensor on the v8 in the pipe work near the air filter box?
Old 13-01-2006, 05:25 PM   #5
EDXR8
EDXR8's Avatar
Yep that metal thing that bolts onto the airbox, and the rubber piping from the throttle body attaches to.
Old 13-01-2006, 07:47 PM   #6
NZ
NZ's Avatar
the thing with a hole the size of a bee's dick.
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2006, 07:48 PM   #7
svo347
AFF's 1st DM.......
svo347's Avatar
Failing that id get your injectors cleaned..
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
