08-01-2006, 05:45 PM | #1 | ||
BF F6, APV SR3900
hey all... this is what i have planned for next saturday possibly friday...
1. Rear Main 2. Possibly Clutch while im at it 3. Sump Gasket 4. Possibly Timing Case Gasket 5. Valve Stem Seals 6. Cam Change while im at it (probably Wade 1636) 7. Possibly Valve springs if i go a heftier cam 8. New Rocker Cover Gasket 9. Possibly paint rocker cover metallic black (from blue) to match car exterior... anyone using a Wade 1636 grind? or other grind a bit beefier.. any feedback? would there be any other seals/gaskets to replace that probably have gone hard which would be easier to do at the same time... cheers, santo
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
08-01-2006, 08:05 PM | #2 | ||
aii santo, i have a wade 1636 grind, it has increased torque, love it, much better in a manual !
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
09-01-2006, 12:36 AM | #3 | ||
Two > One
Santo, seing you have a 5speed i wouldn't bother with the 1636. I'd just bolt in a 1004/114 or 977b.
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
09-01-2006, 12:48 AM | #4 | ||
welsh plugs man
change the steel welshys with copper ones coz thay will rust over and form probs for the head and if u take the box off to change the main middle welshy u can also chand the main seal around the crank behinde the flywheel pat |
09-01-2006, 12:08 PM | #5 | |||
BF F6, APV SR3900
09-01-2006, 12:49 PM | #6 | ||
BF F6, APV SR3900
Ok... after a bit of talking, i ordered a 977B.. apparently it will run okay on stock springs?
lift at TDC is .512... sound about right? any feedback on this cam?
09-01-2006, 12:50 PM | #7 | |||
BF F6, APV SR3900
nah, my cousin is a mechanic we'll be doing it on a hoist thank god..
10-01-2006, 01:01 PM | #8 | |||
BF F6, APV SR3900
13-01-2006, 06:15 PM | #9 | ||
BF F6, APV SR3900
OK!
1. Clutch and Rear Main Complete.... found all screws on sump loose...? 2. Oil and filter changed 3. Cam, Valve springs, Stem Seals + gaskets purchased... 4. Sourced compression tool and spring compressing tool... 5. If all goes well i should be attacking the cam and springs tomorrow + stem seals. Tensioner has to come off doesnt it? Also how would i accurately change the timing (on distributor) from 23deg to 22deg? thanks... santoitaliano
13-01-2006, 06:30 PM | #10 | ||
Sump screws should only be 8N or so otherwise you push the gasket out.
Sundeep |
14-01-2006, 10:02 AM | #11 | ||
[EBGLT]
How did you go with all that stuff mate?
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
15-01-2006, 11:50 PM | #12 | ||
BF F6, APV SR3900
ok....
today did valve stem seals, heavier springs and cam, put it all together and it is all spot on... still adjusting/getting used to the new clutch... but apart from that, omg what a difference... this cam is great... im still running it in so can't really push it yet but tonight started to give it a bit and it has a lot of pull... idle is very lumpy but stable, lovely sound too...
