Old 22-01-2006, 06:03 PM   #1
xr8 007
xr8 007's Avatar
Default Power Steering Fluid Change!
Hey all!
I'm a little low on power steering fluid on my AUII XR6, should i just top it up or flush it then top it up with new fluid. If so whats the best way to flush it out??
(The fluid is under a year old as ford had to re-seal my pump under warranty)
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2006, 08:14 PM   #2
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
If you had your pump re-sealed less then a year ago, i would be very cautious - top it up - and if it goes down again any time soon, get your pump resealed again. Just like brakes, power steering is a sealed unit, therefore, in theory, you shouldn't lose any fluids (under normal conditions).
So top 'er up, and watch your fluid levels - if you warranty is about to run out - advise Ford of this potential problem, and if it is what you think it is, they will fix it as long as they know about it before the warranty expires.
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2006, 08:47 PM   #3
xr8 007
xr8 007's Avatar
cool thanks for the input. Would it be wise to mix oils or drain it out by taking the high pressure hose off???
Old 22-01-2006, 09:24 PM   #4
cArSiK
i too am trying to work out how do drain the fluid from the power steering - rack and all. The problem with pulling the high pressure hose off is that it only drains the pump , not the rack...there must be another drain plug on the rack somewhere...
james
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2006, 04:26 PM   #5
xr8 007
xr8 007's Avatar
well there kinds is! umm two hoses that connect into the rack, which are pressure hoses, that should do the trick. Had a look under the car today.
Old 23-01-2006, 05:25 PM   #6
cArSiK
yes however those two hoses are located at the very top of the rack , obviously the oil below those hoses wont drain out :nutsycuck
Old 23-01-2006, 08:30 PM   #7
Baboon_AU
Baboon_AU's Avatar
in my bible it just says to pull the pressure hose of the pump resevoir.,.nothing about draining from the rack itself... i wouldn't have a clue as i get an Automatics place to service my rack and tranny every 50 000km's..
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
