26-01-2006, 10:09 PM | #1 | ||
Hello everyone.
I’m looking at an EL Fairmont Ghia on the weekend and I was wondering if someone could please help me by telling me where I need to look to find the VIN and engine numbers of the vehicle? I need to perform a REVS check, so this information is important to me. Thanks in advance. |
26-01-2006, 10:59 PM | #2 | ||
[EBGLT]
Under the bonnet mate!!
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
26-01-2006, 11:09 PM | #3 | ||
Engine number on my car is just under the exhaust manifold under the runner for piston #1. Should be the same for EL
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
27-01-2006, 12:33 AM | #4 | |||
27-01-2006, 02:44 AM | #5 | ||
VIN plate is up near the firewall on passenger side.
27-01-2006, 08:48 AM | #6 | ||
PM me if you want
vin and manufacturer plate should both be near the passenger bonnet hinge.
engine number is driver side on the block around #1 piston as said.
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
27-01-2006, 02:55 PM | #7 | ||
Thanks everyone for the help.
27-01-2006, 02:59 PM | #8 | ||
Engine number isn't behind water pump/under #1 plug on EL. It's stamped on the back of the engine block on a flat bit, in the middlish, right near where it connects to the bellhousing. Take a rag and spray some degreaser or water on the back, wipe the crap off and you should be sweet.
Always consult your owner's manual for advice, not FordForums : Get it right damn yaz. Sundeep |
