Old 26-01-2006, 08:14 PM   #1
bab
Default overheating ef 11
just cruisin down freeway today and after about 15 minutes at a 100 k's the temp gauge slowly rose to high point of normal.the pointer hit the O,i pulled over and the top up tank was really gurgling as if air was in system,i put the heater on to try and see if it would make a difference but no change,the heater sometimes runs hot through the vent and sometimes runs cool air out,i changed the coolant last week,have i got a air lock problem or could it be something else,any help aprreciated bab.ps it is a series 2 ef fairmont with 120000 kliks on speedo
bab is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 08:39 PM   #2
edfairmint
i aint sure what the temp gauge on the ef looks like but on me ed pointin to the 0 in normal is fine like goes up to that and down once it gets operating heat
edfairmint is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 10:37 PM   #3
efgiar
rofl copter
efgiar's Avatar
ef2 hav the normal going from top to bottum, so O is pretty high temp. are u sure ur thermos are kicking in?
GQ patrol.
thats all
Old 26-01-2006, 10:40 PM   #4
LUXO_8
windsor user
did you add the coolant the propper way..turn the .heater to full.... fill it up with the cap off and run the car for about 5 minutes......
top up as nessecary.....
this purges any air that might have been in the system...
Old 26-01-2006, 10:54 PM   #5
snypereb
[EBGLT]
snypereb's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
I got told the other day to drain the radiator and start all over again it worked i drained it and took it out cleaned it out now i have no problems at all!!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 09:11 PM   #6
bab
i have fixed problem,put new radiator in today,temp now in loe part of normal
