Old 16-07-2014, 04:01 PM   #1
XWGT
Powered by Marshall
XWGT's Avatar
Default How close are the Miami 5.0 and Jaguar 5.0?
I note the new Jaguar F type R has a 5.0 supercharged V8 producing 404kw.
Magically that is what FPV claim from their 5.0 supercharged V8. Almost identical
Does anyone know technically how close these engines are?
I note no one has any issue with Jaguar quoting 404kw form a blown 5.0. However when FPV did it the world stopped and it was scrutinised to within an inch of its life.
I'd be interested to hear from anyone who knows the tech specs and can expalin the similarities or disparities of these two engines.
Powered by Marshall
XWGT is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2014, 04:04 PM   #2
XR Martin
XR Martin's Avatar
Default Re: How close are the Miami 5.0 and Jaguar 5.0?
They arnt related at all.
2004 BA wagon RTV project.
Old 16-07-2014, 04:05 PM   #3
Luke Plaizier
Lukeyson
Luke Plaizier's Avatar
Very good question. The AJ-V8 Gen III was developed under Ford's watch wasn't it, and the Miami came along not long afterwards.
It really does make you wonder how much of one went into the other.
Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it.
Luke Plaizier is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2014, 04:09 PM   #4
XWGT
Powered by Marshall
XWGT's Avatar
Lukeyson
I know ProDrive did all the R&D etc but I'm sure that Jag was part of the Ford camp around that time before being sold off.
I just wonder what the tech specs of the two engines are and if they are similar
Powered by Marshall
Old 16-07-2014, 04:58 PM   #5
Rodge
Rodge's Avatar
http://www.imakenews.com/jaguarplano....cfm?x=b11,0,w
Dual VVT and direct injected for starters and I'm pretty sure they're intercooled too.
Also Jaguar arn't claiming anything about over-boost so the 404 kw rating is good for all conditions. I think the compressdion ratio's are similar.
Other than that IIRC the marketing blurb that came out when the SC engine was launched here claimed it had over 40% Austrlaian made content that was unique to the the engine here.
Rodge is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2014, 05:50 PM   #6
Bent8
Long live the GT !
Bent8's Avatar
That's because the Miami 5.0 was being compared to a 6.2L blown & intercooled V8 which only makes an extra (factory claimed) 26kW !
Doesn't look good for the HSV guys having a V8 from the blue team that's 20% smaller in cubic capacity yet making very similar power..
Anyways, both motors have similar capacities (Miami 4951cc vs Jag 5000cc) and almost identical bore and stroke specs.
Also interesting to note the early Jag blown 5.0's made 380kW/625Nm, pretty much the same as the BOSS 335's..
2018 Ford Mustang GT - Oxford White | Auto | Herrod Tune | K&N Filter | StreetFighter Oil Separators | H&R Springs | Whiteline Vertical Links | Ceramic Protection | Tint
"Whatya think of me car, XR Falcon, 351 Blown Cleveland running Motec injection and runnin' on methanol... goes pretty hard too, got heaps of torque for chucking burnouts, IT'S UNREAL !!" - Poida
Bent8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2014, 02:05 AM   #7
barnz_xr8
Turbo 358W
barnz_xr8's Avatar
the Miami/coyote is a modular series engine and a evolution of the 4.6l but with new heads, bigger bore, more stroke, I would say the jag v8 is unique to jaguar/ landrover
barnz_xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2014, 09:25 AM   #8
XWGT
Powered by Marshall
XWGT's Avatar
Ok so what I'm gleaning here is that technically they are not close at all.
Thanks for the replies guys
Powered by Marshall
Old 17-07-2014, 02:40 PM   #9
barnz_xr8
Turbo 358W
barnz_xr8's Avatar
yep probably don't even take same spark plugs.
Old 17-07-2014, 03:48 PM   #10
madmelon
They're both very different engines but Jaguar did get one bit of the tech from the Coyote- the cam-torque actuated VCT. That's not to say they have the same cam phasers or anything, just that they use the same VCT actuation concept developed by Ford. I understand it allows for a more complete function at low RPM when there isn't much oil pressure/flow available.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2014, 07:01 AM   #11
XBGTFGGTP
XBGTFGGTP's Avatar
I believe the Coyote and Jag engine both share the same bore spacings and a few other common design principles Even though parts may not interchange.
Current Rides:
XA GT Manual
XBGT Manual
XC GXL
1982 XE S-Pac V8
2011 F6 Velvet
2011 GT Manual Black/Gold
2020 GT500KR
FG-X Sprint
F150 Shelby
XBGTFGGTP is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2014, 10:39 AM   #12
BlueOvalPrint
http://en.wikipedia.org/wiki/Jaguar_AJ-V8_engine
http://en.wikipedia.org/wiki/Ford_Coyote_engine
BlueOvalPrint is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2014, 10:44 AM   #13
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
I'm not sure on that. The Ford shares it's bore spacing still with the 4.6 Modular, I'd be surprised if it wasn't the same for the 4.2/5.0 Jaguars.
They do both have near square bore/stroke ratios though
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
