Old 29-01-2006, 12:00 AM   #1
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Default Intermittent loss of head lights????
Has anyone had a problem with the head lights on their e-series where the high and low beam just turn off for no reason then come back on after about 10 seconds (parkers stayed on).
Happened to me 3 times in first 5 minutes on the way back from heathcote tonight, bloody scary both headlights just cutting out. Then never played up again.
I'm thinking either the relay overheating, or a bad connection with the switch on the dash.
Any ideas???
Daily driver
98' AU 349ci Fairmont Ghia on LPG
Other
93' ED 5spd 4.0L NA Fairmont
13.75 @ 101mph
V8 Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 12:09 AM   #2
XR Martin
XR Martin's Avatar
Is the circuit breaker, which should be along the driver front guard near the radiator bottle. Its metal and rectangle shaped with two individual wires coming from it. Fairly cheap to replace.
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 12:11 AM   #3
Obriza
Obriza's Avatar
I had that once, ended up being a faulty relay. Had to solder it together as it fell a bit loose, Id say check that first.
Obriza is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 12:25 AM   #4
Racecraft
they call me Tibbo
Racecraft's Avatar
agree 100%
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 01:10 AM   #5
snypereb
[EBGLT]
snypereb's Avatar
Check your wiring and your earths its probably something really small!!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 01:37 AM   #6
efgiar
rofl copter
efgiar's Avatar
lol no headlights, ask john about that one :P was a fun trip home lol
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 01:45 AM   #7
efgiar
rofl copter
efgiar's Avatar
/me enters stealth mode haha
GQ patrol.
thats all
Old 29-01-2006, 02:27 AM   #8
5L
[ 5L ]
5L's Avatar
i had a similar problem like this the other week, but was only my drivers side light turning off, turned out to be the plug that goes in to the back of the headlight came unclipped.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline)
www.ignitionimages.com
5L is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 09:05 AM   #9
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
its that thing replace it or clean it up mine was all rusted and stuff i cleaned it up and it was fine
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
TURBO_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2006, 04:09 PM   #10
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Thanks for the replies, I'll try replacing the circuit breaker.
Daily driver
Other
13.75 @ 101mph
Old 30-01-2006, 11:43 PM   #11
5L
[ 5L ]
5L's Avatar
in ed monty's pic i think that i found those two wires in my car and they werent hooked up to anything, and my headlights work fine. ill check tomorrow
Old 31-01-2006, 01:43 PM   #12
Stav
Smile
Stav's Avatar
Its most probably you headlight relays.In your car I think they sit next to your battery but water gets in over time and wrecks them.Also corrosion stuffs the contacts up.Either way try another relay and clean the contacts on both sides. Also make sure your battery is bolted on tight.
Old 31-01-2006, 03:30 PM   #13
TickfordXR
TickfordXR's Avatar
I also have a similar problem only my headlights cut out when i put the high beams on... the high beams will work for about 5 minutes then it will cut all the lights out in the whole car and they dont come on for a minute or so... would it be the same thing?
White EL Series II XR8, manual, high flow cats, single 3" exhaust and Quarterhorse = 236rwhp and 14.18@97.5mph
LOWXR - Back to stay - Awaiting forged bottom end
TickfordXR is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 08:45 PM   #14
5L
[ 5L ]
5L's Avatar
hahaha yeh i came up with that for a plate a while back, ive never had a quick enough car to put it on though, just me being a smart a$$. i was also thinking bout gettin cyam8
