21-01-2015, 01:28 PM | #1 | ||
Anyone no what size the bearing on the ac compresser pully is ?
21-01-2015, 03:53 PM | #2 | ||
Au Falcon = Mr Reliable
Hi Redxr601 & welcome to AFF, i dont know the size of the bearing but if you dismantle your a/c compressor & take the bearing down to a local bearing place they can measure it up & supply one one for you. Good luck!
cheer's, Maka
22-01-2015, 09:24 PM | #4 | ||
Out with the verniers then...
04-02-2015, 11:12 PM | #5 | ||
And does anyone no if a El falcon gearbox will go in my au xr6 series 2?
08-02-2015, 11:50 PM | #6 | |||
Unless someone jumps in here & says "yes", then it may require both gearboxes to be placed on the ground next to each other & compared/measured up. If you're keen on the exchange, get a couple of junk casings/bellhousings & see how they compare. I don't think the engine blocks have changed much, but the "bellhousing to engine" bolt holes may be different, & the gearbox cross mount would be different. Then there's the electronics/speedo to consider. Again, I'm guessing here. |
09-02-2015, 12:13 PM | #7 | ||
Okay thanks I don't know what to do my gearbox slips then u give it a rev or to and it pops in only sometimes tho maybe a oil change will fix it ? Any ideas?
12-02-2015, 11:14 AM | #8 | |||
5.6L x 2 pilot
According to the work shop manuals, both 6 cyl EL and AU run a BTR 93LE tranmission, and both are controlled from the EECV ECU. My guess is that they would fit. Stu
