Had coil packs replaced on my BA around 18 months ago.Around 10k since and again it looks like I have faulty plug packs.
Decided to take a look at them before paying to have another set fitted only to discover at least one of them is different to the others. Seems fairly obvious that although they charged for a new set 18 months back they didn't actually do what they charged me for. Do I have any recourse in this situation? If so what should I be pushing for? |
Do you have receiptfor the work done?
Previous Rides Bionic BA MKII XR6T 245kW I6 Turbo, 6spd Manual Grey (yuk what was I thinking) AH Astra CDX Coupe 93kW NA I4, 5spd Manual Sensation FG XR8 290kW NA V8, 6spd Automatic Current Rides Octane GTF SC V8, 6spd Manual, Manta 3" X pipes and hotdogs Starlight Lotus Evora S 258kW SC V6, 6spd Manual |
Sounds to me you can at least ask the question...
What is the difference you mention? Will it support your statement they didn't do what you paid for?
Mustang GT mmmmmm......
Heres a link to warranty info.
http://www.ford.com.au/ownership/genuine-parts You will have to see how generous they are.
I have become a Mustanger. |
#6 | |||
The other 5 have no sticker and are numbered FI1ta 9194ca 5r2u-12a366-aa and are clearly visually different to the rear one. Even though it has been a fair while since it was done it is more a matter of principle for me.Why would feeling generous on their part even come into it given that it really does seem they ripped me off originally? |
Even if it's outside the warranty period and they refuse to replace you can still launch a case through VCAT. It's become a regular thing for me unfortunately given how most small businesses these day care not for quality service and only for turnover. 18 months for coil packs (average expected life of 200 000km/10yrs+) is completely unreasonable regardless of the given warranty period. There's a very good chance you will get a refund/replacement regardless of whether they're still under warranty or not. Consumers still have rights in this world despite right wing governments and media influences currently wanting to shift that. So if you have any issues make sure you always lodge a claim through VCAT/consumer affairs (easily done online). Infact I always do it immediately anyway even if the dispute is yet to get heated to ensure I have indisputable documented written evidence I've claimed/lodged a dispute at the critical time since the issue arose. Go to consumer affairs website it takes 5 minutes to launch a claim, highly worth it.
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come! |
Fan of torque steer
Ford did go through a change around 18 months ago. You may have just had a mix of the old & new stock fitted, they do work & fit identically. The 5R2U coils are the later release units.
2015 LZ Focus ST, Frozen white with tech pack. Mountune intercooler, intake, Mountune sports cat, Mountune cat-back and Cobb stage 3 tune. FSwerks short shift and the best performance upgrade yet - Michelin Pilot Sport 4's. Quaife LSD. |
Go have a talk with them, they might cover the parts since you have low K's.
Where to next??
Do they have equal amounts of dust/grime on them?
May I ask what city this work was done in? Yes they probably will try to fob you off.. Be firm yet persistent if you truly believe they have done the wrong thing.
___________________________ I've been around the world a couple of times or maybe more....... |
Now Fordless
If it was within a year i think you would have a chance. Not after 18 months.
Also has it been diagnosed properly? |
Workshop & Performance
![]() Join Date: Jan 2005
I'm curious what or who is saying the packs are faulty.... Never had. Bad experience with OEM units. Plural failed packs? As per partsguy doesn't sound like there is any case of new and old parts just smacked fair square on the changeover time.
2005 LS Focus 2.0 LX daily bye bye 300000km 2004 Kia Cerato 2.0 amazing workhorse 2005 Mazda 6 MPS shiny thing garaged 2008 EO XR5 might finally be for sale shortly I promise myself |
#13 | |||
It seems a bit odd that they wouldn't replace the 6 new coils with 6 of the same brand . |
#14 | ||
Bit of a follow up.
Total and utter stonewalling from ford. The rear coil pack looked totally different to the other 5 and does look to be older than the others based on the stickers on the top of them,the rear one really faded compared to the others,not to mention the different numbers on it. I ended up buying and replacing the rear coil and car is now running really well. Never again will I use ford for anything. |
#15 | ||
Used to be the practice when I worked for Ford that we gave the customer the old parts in a plastic bag, 1972/3 so that may have changed.
Digital cameras are a mans best friend these days. One of the worst ripoffs I've seen was oil filters, remove clean and refit, charge for new filter. None of this stuff is particular to Ford I can assure you. Don't make the mistake of thinking all businesses are above board. From what I've heard from reliable sources one of the worst is computer repair or warranty work, you get your computer repaired but that doesn't mean it's had new parts. Another thing I haven't seen for years is the Gilbarco bloke checking the fuel bowsers for accuracy. |
#16 | ||
#17 | ||
You don't need a digital camera but you're probably fed up with it all now, if you still wanted justice though then send them a "letter of demand" stating what you want for a resolution. Then straight after go down to the local police shop and tell them/emulate what you wrote in the letter of demand, ie that the last coil wasn't replaced, it was a different colour etc. He will write this down on a "statutory declaration" (which is better than a digital camera) and the other party (ford) will is obligated under law to write a response to your letter of demand within a certain period of time (usually only weeks to prevent them from stonewalling the dispute). Once their response comes back disagreeing or even accusing you, then this directly contradicts your testimony on the stat dec (as you emulated both letters to be identical remember) eg if ford says they were new in response to your letter of demand requesting replacements as they're actually old, and your stat dec says the back one wasn't replaced then this is a direct contradiction to what what ford have said. It is a very serious offense to lie on a stat dec and the maximum sentence is 4yrs imprisonment. If you walk back into the police station with the stat dec and fords response (from the letter of demand you sent them) and show the contradiction on the 2 papers to the officer/sergeant he will have no choice but to challenge the stat dec. And since your stat dec is correct the result will verify ford were lying (as I doubt ford are brave/confident enough to state it on a stat dec and for the sake of a sub $100 part). You only really need the stat dec anyway as if the other party isn't willing to pledge one of their own you basically win the case.
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come! Last edited by ILLaViTaR; 03-05-2014 at 05:21 PM. |
#18 | |||
I recently took a vehicle to a mechanic that had been recommended to me and he gave me the used parts so naturally he gets all my work from now on. I don't query the bill, I just request that we don't break down anywhere. I could do this work myself but can't be bothered and trust him to do the right thing. Dealerships are able to withstand a lot more bad feedback from customers than the small businessman, I've spent years working for both and the small business has to look after their customers much more carefully. |
#19 | ||
Nothing sh!ts you more than these types of businesses blatantly ripping ,
(more like thieving ) , people off . Some of us are lucky enough to be able to do a lot of this work ourselves , but you must wonder how many other people have been ripped off . I hope you get some positive result out of this , jerk it into them . Further to the issue with my car , where it had a miss at idle it turned out to be an inlet manifold gasket , luckily i didn't change the coils out , but i did get one of our local mechs to do the job for me , and whilst it was still on the hoist he showed me the old gasket . |
#20 | ||
So 18 months ago you paid for all six packs to be replaced, and one is now failing after 18 months and 10k
I would approach them under Australian Consumer Law that parts must last a reasonable amount of time and 18 months and 10k is not reasonable to me |
#21 | ||
When they did the job originally , did they diagnose the problem with their
diagnostic tool , and have they charged you for that service on your receipt ? How many K's were on the car at that time ?, as my car has 126,000K's and the coils are still good , so you should be getting more than 10 k's out of them . |
#22 | |||
I want to know if it's worth changing the coils as well as the plugs.... |
