Old 04-10-2014, 12:57 PM   #1
Scarelvis
Default Smartshield and Engine Management
Hi guys. I'm seeking any advice on my 2001 AUII, 6 cyl, auto ute. I recently tried to jump start it using the correct cables with a resistor or whatever on them a I've had the same problem before from putting the earth to terminal instead of the block.
Now on start up, after connecting fully charged battery, the instrument cluster says BASE. When I turn the key to start I have all bright dash lights, but no engine turn over. I've checked starter and it's fine. When I previously had the same problem, I'm pretty sure that after diagnosis comp was connected the mechanic went through some sort of sequence with the key an all sorted.
Please help guys. I'm on a farm so it'll cost an arm and a leg to get a tow. Plus my mate lent me a car, but it's a Torago bus. And I think my dogs prefer the ute.
Scarelvis is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2014, 03:17 PM   #2
Ride
Stay Classy ™
Ride's Avatar
Default Re: Smartshield and Engine Management
Seems that the computer has 'forgotten' your keys. You'll need someone with an IDS tool (there are some mobile services around) to re-program your keys.
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2014, 07:05 PM   #3
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
Is the smartshield lamp flashing when you try to start it?
Even if the keys are forgotten the engine will still crank.
No cranking would indicate inhibitor switch. Cycle the shifter down to 1st and back and try again.
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2014, 07:46 PM   #4
Scarelvis
The light is on, not sure about flashing as its been a week since I tried it. I just put the battery on charge this afternoon to make sure it's fully charged by the morning to try out any hints you guys passed on. The starter doesn't wind over with key but I read on here how to remove the relay and wire up 2 pins and she's working great. Thanks heaps for your help. I'll let you know if it flashes in the morning.
Old 04-10-2014, 08:04 PM   #5
Scarelvis
Loved the defence of the mini van. That is exactly what is used for. And parked beside the creek right now.
Old 05-10-2014, 11:57 AM   #6
portokatsiki
after you charge the battery turn the ignition on and leave it on for an hour for the car and the ecu to get synchronized. if that doesnt work you might need to get the IDS like someone suggested. IDS i think is also called parameter reset had it done on my AU 4 years ago at a dealership good luck
portokatsiki is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2014, 02:23 PM   #7
Scarelvis
Light is on but not flashing.
Old 28-06-2015, 12:40 PM   #8
johnadams
I'm running into the same problems as you did, did you ever find an answer and how did you fix the car. A happy ending to your thread would be good.
johnadams is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2015, 05:12 PM   #9
david lee
i had the same problem in myxr6 no nothing. was the computer under the dash replace with a second hand one and reprogrammed lucky it happenened 1 street from my mechanic
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2015, 05:20 PM   #10
johnadams
Any chance you remember if the mechanic was able to reprogram it or did it have to go to Ford and was it a BF or earlier model?
Old 30-06-2015, 08:50 PM   #11
david lee
second hand computer $80 new aprox $600 mechanic reprogrammed it its a au xr6 aparently the computer is under the dash to the left to the steering column and must be removed first to identify which color it is.it must be matched to the replacement one.my mechanic tried to reprograme to old one to no avail
Old 01-07-2015, 12:33 AM   #12
johnadams
Thanks.
