Go Back   Australian Ford Forums > Ford Australia Vehicles > Small and Mid Sized Cars > Cougar and Probe
Old 03-07-2015, 12:30 AM   #1
neo
NeoProbe
Default Probe engine shudder
Hi guys,
My 1996 Probe (Manual) engine shudders noticeably when I put it under load (anything over 3000 rpms) especially going up hills.
I had the engine rebuilt 6 months ago and kept getting a check engine warning code for a faulty EGR valve. I replaced that along with the O2 sensor but the warning light remained. The engine shudder developed a month later.
I've taken it to 3 mechanics now and they are all scratching their heads.
Has anyone got any idea as to what the problem might be?
Neo.
neo is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2015, 04:05 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: Probe engine shudder
I'd be checking engine mounts as a possible cause.
Russ
Observatio Facta Rotae
Old 03-07-2015, 04:05 AM   #3
russellw
russellw's Avatar
Russ
Old 03-07-2015, 06:20 PM   #4
neo
NeoProbe
Thanks Russ. I've also had advice to check the timing belt.
Old 05-07-2015, 03:24 PM   #5
DRU842
Plug leads for mine.
2017 Mustang Lightening Blue, Cobb Intercooler, CAI, AccessPort, Turbo Blanket & V2 Exhaust, Mishimoto Down-Pipe & Overflow Tank, GFB DV+, Custom CRD Tune. Ford Performance Short Throw Shifter & Strut Brace. DBA T3 Brakes & Pads. Braided Brake Lines. H&R Coilovers. Anderson CF Track Pack Spoiler & Tailgate Panel. Blue CF/Leather Steering Wheel.
DRU842 is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2015, 11:06 PM   #6
neo
NeoProbe
Thanks Dru. I had the leads replaced when I got the engine rebuild 6 months ago.
Old 06-07-2015, 11:19 AM   #7
thearrow
Is this a 4 or 6 cylinder ??
Owning a Cougar is like owning a Super Model
Good to own but "High Maintenance"
2000 Model Eibach Cougar (Auto) - Now dead & buried
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2015, 05:05 PM   #8
neo
NeoProbe
It's the V6. It looks like it may be a CV joint problem.
Old 07-07-2015, 11:53 AM   #9
neo
NeoProbe
Yep. Turned out to be a L/H drive shaft replacement.
