Old 11-07-2015, 08:21 AM   #1
xr8 007
xr8 007's Avatar
Default Coolant leak help with pics!
Hi all,
Got a small water leak that happens from time to time which is weird cause it doesnt happen all the time.
Source seems to be the area around the thermostat housing. Pics of the leak source.
The top hose is not suspect as its dry when the leak is there. I am suspecting its that black pipe. Can this pipe be replaced or do I need to change the whole housing area? Is there any other way I can go about fixing this?
thanks in advance
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2015, 09:09 AM   #2
T MAN
T MAN's Avatar
Default Re: Coolant leak help with pics!
there is a o ring where that pipe goes into the housing, just un bolt it , give it a wiggle or 3 and it should come out
T MAN is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2015, 11:28 AM   #3
Spurious
You're not the only one mate.
Last time I did engine work, the mate who was helping me smeared some high temp sealant on the fitting when it got put back together.
Prior to that it would on rare occasions leave a little telltale white mark on the A/C compressor.
It's a heater flow pipe & thus it may leak if & when the heater tap is turned on & off. That's what I figured anyhow.
With sealant mine hasn't leaked in a year.
Spurious is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2015, 08:12 PM   #4
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
I put a thicker o ring on mine combined with high temps sealant. Hasn't leaked since.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2015, 07:43 AM   #5
xr8 007
xr8 007's Avatar
Thanks gents for all that info. Will get it fixed today. Thanks again, Tman, TasmanWw and pridenjoy!!!
