Old 08-08-2015, 10:34 PM   #1
david347
Default v8 clutch
hi all i just installed a new clutch into my 220kw v8 but i think it is wrong as when i put the cable on the pedal is still on the floor. the throw out bearing is no where near the clutch fingers. is it possible i put the clutch disc in backwards?
any help would be great
cheers
david347 is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2015, 09:13 PM   #2
bluestripes
Q - CAR
bluestripes's Avatar
Default Re: v8 clutch
cheers
So what did you do wrong ??
AU FORD STROKER
347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned.
bluestripes is offline   Reply With Quote Multi-Quote with this Post
