25-08-2015, 05:33 PM | #1 | ||
Hi all, I was after a bit of advice about fiberglass bumpers. I'm going to go for a TS/TE50 T3
style bumper, obviously an aftermarket fiberglass one and after lookining on the internet I've have discovered 2 things. 1, many different companies do them and 2, a huge range in price. I have seen them from under $300 on E bay and as much as $850 from a fiberglass body kit manufacturer/retailer. The only difference being primed and coming with the mesh on the cheapest and most expensive ones. Then there are all the prices in between eg $380, $$570, $495 etc. So who's bought one from where and are you happy with the product. I did my search before posting this new thread and found a poll but not a lot of info. My point is with the huge difference in prices are the cheaper one only good for ornaments on your shed wall? The difference is too great for me to rush into buying one and I'd really appreciate information with people who have, or know people who have had experience with them. Thanks and look forward to some sound advice.
Losing my patients with unfinished threads Did the ideas people helped you with work or not! |
25-08-2015, 05:40 PM | #2 | ||
AU3 5.0L Fairmont Wagon
The two that's I've had both cost me around $250-$300, only the second one came with the mesh but I put the standard honeycombs in the top part anyway. I don't see any need to spend $800 as long as the cheaper ones are correct fits.
They should all come in gelcoat teat to prime and paint. Regards Ray
5.0L, 2.1l Kenne Bell, Tickford T3 Heads, Crow valve springs, YellaTerra 1.7 Rockers, Comp Cam, Comp D-Row Timing, 10mm LiveWire Leads, LC-1 & Moats Quarterhorse, B&M TransCooler, Walbro 255lph Fuel Pump, King Superlow Coil Springs, John Bowe Superlow Pro Leaf Springs, K&N 4" Pod & CAI, Pacemakers, 100c Cats, 2.5" Redback, 19" FPV Rims, BF-T Prem Brakes, TS50 Bumper with DTRL's, Custom FG Bulge, BA XR Side Skirts/Rear bar Ford Performance Club of ACT [SIGPIC][/SIGPIC]
25-08-2015, 07:04 PM | #3 | ||
Good stuff Ray, cheers. Like most stuff these days it's hard to get bad things that are useless and
break or don't perform as they should like you use to years ago. Sure not all things are created equal but they all perform well eg TV's
26-08-2015, 03:18 AM | #4 | ||
KarlFromWa
I brought one of eBay I'm pretty sure it was pride composites for around $380.
Once I finally got it, the next problem was too make it fit- which definitely wasn't show quality but did require a bit of work to make it fit, and once I did the gaps weren't perfect. Then I got it painted which wasn't as simple. The painter said it had a lot of pin holes all over It. Again it was fine for the car. And I wasn't after show quality. It is fibreglass after all Other than that, make sure you keep it off any kerbs Etc, they don't take a liking to any touching. Good luck mate
DAILY: 2014 Kenworth k200.. 550hp.. 18 speed Cummins.. Topstart Pocket R/Train WORK UTE: 2001 Au2 Xr8 ute.. Vortech supercharger @ 12 psi.. Rip shift.. 19" Speedy Cheetahs.. 450rwhp FUN: 2013 FG GT Mk2 No: 1317 White.. 6 Speed Manual.. Leather.. street fighter kit .. Full custom stainless steel.. 680rwhp
26-08-2015, 10:38 PM | #5 | |||
I mentioned I've seen them for around the $300 mark and every where in between. I've decided I'm probably going to get it from Repliglass as I need another item from them so seems they're in QLD am I'm in WA I may as well bundle them together, that is unless people advise me otherwise. I plan to order at the end of next week. Thanks again.
27-08-2015, 01:35 AM | #6 | ||
KarlFromWa
I'm pretty sure that's the same one I got. Go for it, a lot cheaper than genuine
27-08-2015, 09:39 PM | #7 | ||
After a bit more research on the inter web I best stay away from Repliglass for a front bumper at least,
and almost all fiberglass manufacturers. What horror I've been reading form Ford to Commodore to Jap car forums, scary stuff. I'll give AWC a call(Fibersports) they seem like the best for quality. Even SSV which was the most expensive I found got a lot of bad reports. With most manufacturers of fiberglass I wasn't just finding 30% bad and the rest satisfied, I'm talking most, at a guess over 85% people being VERY disappointed in their purchased product. I do plan on getting a HO style FG bonnet scoop, its a FG hump with vents, and no it's not to rice my car up its for clearance for some mods and it needs some heat extraction big time. Anyone know where I can find this FG bulge with vents I speak of. The HO site seems it no longer operates and Repliglass is the only one I've seen. Worst case scenario if its low on quality it shouldn't be hard to fix.
27-08-2015, 10:01 PM | #8 | ||
fibresports is where I got one from a few years ago and it was pretty good, but they closed down in 2013..
I have heard that they are now prime composites, but cant confirm it... |
27-08-2015, 10:31 PM | #9 | |||
http://www.fibresports.com.au/ Just went to the site sponsor section and there is no mention of any body kit company listed. I thought this because with all this searching I've been doing I saw "see AWC the site sponsor" mentioned multiple time
28-08-2015, 12:10 AM | #10 | ||
Spanner Thrower
Ask Ray. He made an fg bulge bonnet for his au wagon.
1999 AU Futura Wagon (Nickname Betsie the Barge-***) Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG. Awaiting Wife Approval Mods: TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things! |
28-08-2015, 07:23 AM | #11 | |||
29-08-2015, 09:45 AM | #12 | ||
If I do go a front bar even though its nearly double the cheapest price I've see I'm inclined to get from a
local supplier and fitter so I would have a better idea of what I'm getting, instead of a nasty surprise. I read a rumor on here (AFF) that the original molds for the T3 TS/TE50's were in the hands of The Spoiler Shop here in Perth but I'd take that with a grain of salt. I wonder why they don't produce the bumpers or any part of the body kit, I mean the molds are somewhere and with all the fiberglass ones that have been sold there is a market for them, and if people had a choice surely people would choose the plastic over fg. For now I'm just going to sit on the idea.
30-08-2015, 04:40 AM | #13 | ||
Pro Street Au Ute
AWC might have closed but when going through the bumpers/spoilers on ebay, there's a seller using all awc's pics. I'd be hitting them up for a bit of info. Back when they were around I heard they were about the best there was. I'll be enquiring about p250 skirts and rear bar from them.
Daily. AU XR8 s2 ute auto Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker. |
30-08-2015, 09:51 AM | #14 | |||
quality of finish and slow turn around time. I also read a thread on here that AWC/Fibersports were still taking money and orders and the shop was closed down and nobody was told.
