Old 26-09-2015, 02:09 PM   #1
Falcon56
Falcon56's Avatar
Default Steering alignment out after servicing at Ford
So I took my XR6T into my local Ford dealer for its 45,000km service on Thursday. Sheared diff bushes got replaced under warranty, but other than that just an ordinary service.
Didn't notice anything amiss when I drove it home Friday morning, but driving to work later on I noticed that to drive straight, I had to have the wheel turned a bit to the right. If I had the wheel in the most upright position, the car would turn left quite rapidly.
I just want some opinions on the best course of action. Take it back to Ford to get this fixed (hopefully for free), or take it to somewhere like Pedders or Beaurepaires and pay for a realignment?
Cheers guys
Just arrived: XR6 Sprint #259 in Kinetic
Previous ride: 2012 Auto XR6T Limited Edition in Swift Green
Falcon56 is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2015, 02:25 PM   #2
sprintman1
Default Re: Steering alignment out after servicing at Ford
Cheers guys
Typical. Just had the rear wheel bearings replaced on daughters Forester and it was way out after. Quick trip to the suspension shop and $56 and all correct.
sprintman1 is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2015, 03:16 PM   #3
NTF6
Both of my FG's had there steering wheel slightly to the left from new, I just got used to it. I don't know why they can't build them straight from the factory. Audi and BMW can.
2017 Mustang GT (Magnetic)
NTF6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2015, 03:38 PM   #4
mik
mik's Avatar
They should have caught that on the pre delivery, half the problem there is getting the bloke... woops ... person /mechanic/apprentice doing the PD that is conchy enough to not say, "she`ll be right " , and just tick the box instead of actually checking the alignment, a common fault in some dealers unfortunately.
Old 26-09-2015, 05:37 PM   #5
Top_Ghia
Technical Contributor: For members who share their technical expertise. - Issue reason: has been consistently providing good technical advice etc. to AFF members, by having the vast technical knowledge he has with the various Ford products. A valuable AFF member
If they did diff bushes they've had the irs out. Your problem is the irs unit hasn't been put back in straight. Don't get a wheel alignment done. Take it back to the dealer and tell them to align the irs unit. If they look at you stupid find another dealer.
You can check for yourself if you want to stick your head under the back of it. Right at the back where the irs unit mounts to the body is the alignment holes. One is round and the other side is oval and about 1-2 inches in diameter right near the rear 18mm mounting bolts on the left and right hand sides. Also check for witness marks around the mounting nuts. If you can see witness marks around the 18mm mounting nuts then it hasn't been put back in the same spot and will be out.
Top_Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2015, 08:46 PM   #6
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
They may have just rotated the tyres for you.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2015, 09:27 PM   #7
sprintman1
Meaning what exactly?
Old 26-09-2015, 11:28 PM   #8
Falcon56
Falcon56's Avatar
Thanks man, I'll check it out.
Old 27-09-2015, 12:16 PM   #9
Jastel
If your tyres are wearing funny/different it can pull the steering a bit.
So can flat tyres.
Old 28-09-2015, 01:10 AM   #10
If they have done a wheel alignment, (and assuming it's not an uneven tyre pressure problem), then this is a very common complaint from consumers after a poor alignment. The problem stems from the fact that the mechanic has not centred your steering wheel properly before locking it to the foot pedal before making the alignment adjustments. If you have to hold your steering wheel to the right to go in a straight line, it means a simple adjustment to each tie-rod.
In your case, I'd say if your steering wheel is off by just a few degrees and you are going to the left when you centre the steering wheel, then the driver's side tie-rod needs to be turned a quarter turn anti-clockwise to lengthen it, and the passenger side tie-rod a quarter turn clockwise to shorten it by an equal amount, so your alignment remains the same, but your steering wheel now becomes centred and your front wheels are pointing straight.
