Old 29-09-2015, 10:01 PM   #1
sprintman1
Default Re: K&N air filters, whats your opinion?
Originally Posted by 99AUXR View Post
We are still waiting for your point to be proven. You have danced around everything and hinted anything of value would need to be discussed in PM. Also making it out like reading a UOA is some kind of god given gift that only you can do.
So please enlighten us all with the very, very bad data you have on K&N Filters. Im more than open for discussion and will happily learn if Im wrong, but over the last few days I have seen nothing.
Can you read a UOA or can't you? I'm not going to hold your hand
sprintman1 is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2015, 10:08 PM   #2
99AUXR
Brad
99AUXR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Installing starter motor advice on ba / bf 6cyc Falcon.
Yes I can. And you have avoided my question yet again. Im only carrying this on so people don't start following your opinions on K&N filters, unless you can provide cold hard results that state otherwise.
But at this stage I would assume my opinion and testing is sound and there is nothing wrong with the filtration of a K&N filter and anyone who uses one not going to see engine failure caused by the K&N filters 'lack of filtration'.
Two out of thousands? Aare you really that obtuse?
Please move on from insulting members and provide data because at the moment you are only one out of thousands.
Silhouette BF MKII F6
Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10
99AUXR is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2015, 10:15 PM   #3
sprintman1
Use Google, find BITOG, read UOA's. Simple eh?
Old 01-10-2015, 10:49 AM   #4
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Looks like you've got a lot to prove, the only thing you've proven so far is that you can type on a keyboard. Hell you don't even own a Ford so why bother pushing your agenda?
Again and I will state my experience with K&N over the last 10 years.
- Pod filter on a mildly modified AUII Falcon ute, no issues and no dirt passed the filter but plenty in the airbox (used to live on a dirt road)
- Panel filter on a standard BAII Falcon XR6, no issues at all and mechanic was happy with the quality of used oil
- Panel filter on a standard NS Pajero TD, was thrashed and not looked after all that well, yet the filter worked great.
I was looking at getting one for the missus' Lancer but haven't had any luck as yet as the dealer only shakes out excess dirt from the paper filter, which to me means that it could potentially be impeding proper airflow to the engine and causing more issues than a K&N would.
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2015, 11:09 AM   #5
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
Tight *** dealer giving paper filters a bad name!
cheer's, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
