Old 24-12-2015, 11:15 PM   #31
mcfly94
mcfly94's Avatar
Default Re: Coolant - Green Turning Red?
argh this all seems to complicated
4.5l concentrate nulon red, rest de-mineralised water, and done, if you have a clean overflow you get the jist of the mix by colour, i fill a 1l off coolant, 1l off de-mineralised water, have never flushed it, just replaced the radiator instead because it was leaking!
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2015, 11:16 PM   #32
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Is there a vacuum/suction device that you can purchase to remove all the coolant ?.
Old 25-12-2015, 12:51 AM   #33
barrys123
barrys123's Avatar
I don't believe it possible for coolant to be circulating through the motor for a year and for the two different colours not to mix but to stay separated, that's like mixing half of tin of green paint and half tin of red and not expecting them to change colour unless ones oil paint and the other water paint.
barrys123 is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2015, 02:04 AM   #34
Drecian
There's a 'coolant flush gun' that connects to the top hose with a water and air inlet fitting (thermostat out). You drain the existing coolant as best you can, then using the gun fill the system with water, followed by blasting the air into the system, forcing the water back out. Alternating between the water and air flushes it out quicker than the fill/drain method.
https://www.google.com.au/search?q=c..._AUIBigA&dpr=1
Jeff
'99 AU1 Fairlane
Drecian is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2015, 04:23 PM   #35
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Thank’s for that mate.
