Old 01-01-2016, 11:30 AM   #1
inventiv
inventiv's Avatar
Default Rear Strut Towers - Quick Advice Needed
Hi guys, juts need some quick advice. The rears struts on an IRS AU XR8:
And the hat:
So my question is - does the hat go on like this:
Or like this?
I'm guessing the second, right?..
inventiv is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2016, 01:29 PM   #2
towtaltowing
Default Re: Rear Strut Towers - Quick Advice Needed
Second one
1st makes no sense
towtaltowing is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2016, 01:50 PM   #3
rmack
rmack's Avatar
I think you will find its the first option.
LINK TO PROVE
The dimples grad the bottom of the cup to soften lateral forces.
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2016, 06:16 PM   #4
inventiv
inventiv's Avatar
LINK TO PROVE
Hmm, that's odd... My hats were on as per first option, but this caused significant knocking in the rear suspension. When I investigated, the cause was the central thread and nut, along with the hat having significant up down movement, even though the hat was on tight. Also, my hats do not sit snug inside the rubber housings as per the link, but way above like in pics above.
I've flipped the hats and mounted them hard against the rubber mounts (as per second image) and free play is gone. But I'm not sure if this is correct and I'm doing some sort of damage - hence the post.
I'll have to do a bit more digging.... Not sure why my hat doesn't sit in the rubber mounts, or why I've got that much up / down travel when it's mounted right.
Old 01-01-2016, 07:17 PM   #5
inventiv
inventiv's Avatar
Did a bit more reading on this forum, found Sox's epic permanent solution to this problem too! Shame he does not make them any more however. Damn...
On the plus side, some peeps have done exactly what I have to eliminate the unwanted travel - that is, turning the hats upside down.
It's clear though that it's not an ideal solution so it looks like I'm either up for a more permanent fix made by Sox, or a New set of Rear IRS Upper Suspension Mounts.
Anyone got either?
Old 01-01-2016, 08:16 PM   #6
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Can you even get New IRS shock mounts anymore ?.
I need to have a look at mine one day, yes it is a pity Sox doesn’t do them anymore.
