Old 14-01-2016, 06:21 PM   #1
Washburner
Default AUII Dash Vibration
There's a spot somewhere between the A/C Button and the Demister Button on my Forte' Wagon. I here it at highway speed only . I can push my finger on it to shut-it-up' for a while ..till the next Bump, but then it's back again.
Any solutions to this problem would be much appreciated.
Washburner is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2016, 02:03 PM   #2
rayjaymor
rayjaymor's Avatar
Default Re: AUII Dash Vibration
Not sure if it's the same on the AU1 - but the temperature control panel is really sensitive to having the screws loosened.
Pull the front off, make sure everything is fastened and in place, and that all the tabs are there. If that doesn't solve it, use some blue tac to act as a buffer/deadener.
Originally Posted by blake fergo
what is the best way to do a burnout aka sitter in a 6sp manual ute with out burning clutches and causing damage to ur car ?
Originally Posted by FPV+fteT3
The best way not to damage the ute or embarass ford owners is to replace the ute with a VL commo with 15" steelies on the back and slushbox :sm_headba
rayjaymor is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2016, 11:11 PM   #3
Washburner
Thanks Ray,
The Blu tac might be the go . I know that the BCM unit is in behind there somewhere so I dont want to drill a hole or anything. I'll try this on the weekend ..and see how it goes.
