Old 14-05-2016, 05:38 PM   #1
Alpha_omega
Default Focus LW Mk2 how to check error codes?
Hi guys, need your help, got a 2013 focus LW mk2, just noticed the amber engine mulfunction light was on, on the instrument cluster. I tried the system check option from the instrument panel LCD display and it said all system was ok.
How do you check for error codes in this model, should it display it on the system check screen, or is there a way to find out what the problem is.
Engine seems to be running normal.
Thanks.
Alpha_omega is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2016, 06:35 PM   #2
marko
Marko
marko's Avatar
Default Re: Focus LW Mk2 how to check error codes?
You need a scan tool that'll go in the OBD port and connect to your phone. Cost around $15 on eBay.
Or go to a workshop and get it done on their flash $25k machine! They might charge you though, so pick your garage carefully.
May the FORD be with you!
marko is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2016, 06:38 PM   #3
marko
Marko
marko's Avatar
One of these thingy's
http://www.ebay.com.au/itm/Car-Mini-...wAAOSwo6lWQdg5
