Old 02-09-2016, 06:25 PM   #1
T3rminator
T3rminator's Avatar
Default Mobil 1 ATF
Anyone know where I can get Mobil 1 ATF transmission oil in Melbourne?
I've tried Autobarn, Supercheap and Bursons, but none of them have it :(
I know I can get it on ebay, but I don't want to wait a week if I can help it.
Old 02-09-2016, 10:38 PM   #2
EBSXR6
EBSXR6's Avatar
Default Re: Mobil 1 ATF
Repco could be worth a call.
EBSXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2016, 08:30 AM   #3
T3rminator
T3rminator's Avatar
Nup. No luck.
Sent from my SM-N9005
Rides (past and present)
Old 03-09-2016, 01:44 PM   #4
EBSXR6
EBSXR6's Avatar
http://southerncrosslubes.com.au/contact/ they are Mobil Oil distributors.
Old 03-09-2016, 02:48 PM   #5
T3rminator
T3rminator's Avatar
Yeh I wasn't too keen to order it online due to waiting time.
Anyhow, took the plunge and went with the Penrite ProGear 70w75. This is on the Tremec 3650.
I previously had this scratchy / rustling noise in 5th gear at crusing. I tried Mobil 1 ATF and Castrol DEX III, filling it at 3L, 3.3L 3.8L etc using all sorts of combination (although never tried filling it to the top with Mobil 1 ATF, hence why I wanted to try) but the noise would still eventually come back, especially after giving the car a bit of a kicking.
So far the Penrite is quiet as anything, even after giving it a kicking for the last hour. Only downside is that the shift from 1 to 2 is a little bit more notchy than the Mobil 1 ATF and Castrol DEX III. I'll live it if the noise never comes back.
Old 03-09-2016, 02:52 PM   #6
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
yeah I had to order it in when I was trying oil for my tr6060 as I couldn't find it anywhere in perth
FG XR8 Ute 2010 Nitro,
Mods so far: Herrod CAI, headers, Ballistic cats, Cat back Manta dual 2.5" with X pipe and hotdog mid section, Mellings oil pump, Summit racing 60mm twin throttle body, and Yella Terra plenum
Powerbond 25% under drives, Sports bar,
now fitted with Koya Inox R1's, the rears are 20x10 with a 40mm offset and the fronts are 20x8.5 with a 35mm offset
total of 285.5 rwkw and 642nm
when Herrod cams in 290rwkw
GSXR 750K7 with goodies, dyno'd 136rwhp,
10.567sec for the strip
comagutsa is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2016, 04:54 PM   #7
EBSXR6
EBSXR6's Avatar
I know Wikipedia cannot be relied on 100% but this maybe of interest https://en.wikipedia.org/wiki/Tremec..._Fill_Capacity
"Mal Wood Automotive, an official authorised Tremec distributor in Australia, have consistently recommended use of Castrol Transmax Z[2] for use in the Australia Ford vehicles"
Old 03-09-2016, 04:55 PM   #8
T3rminator
T3rminator's Avatar
Yeh that's outdated info unfortunately. I rang Mal and he now recommends any DEX III. Castrol changed their Transmax Z formula and is now not suitable.
He also recommend fill to the plug hole, whereas I've seen ford come out with a TSB saying fill to 3L only to improve shifting.
Too much info and combinations for the same box :P
Old 05-09-2016, 06:43 PM   #9
T3rminator
T3rminator's Avatar
Hmmmm still not completely happy with the Penrite. This morning it was making noise at idle (which it never does) and was crunching into gears excessively.
Have now ordered Mobil 1 ATF. Will trying filling up to the plug hole and hopefully that gives the result I'm after.
