Old 05-03-2017, 08:27 AM   #1
RACERED
Winding roads please
RACERED's Avatar
Default Fuel injector service
Has anyone with a Ford Focus ST had a fuel injector service?
Is it really necessary?
Shouldon't modern cars like ours be engineered well enough to not need one for along time? What are the benefits and what are the signs if any that your car needs one
Cheers guys
Tim.
HURRY UP WEEKEND DRIVE
RACERED is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2017, 01:10 PM   #2
DZFord
DZFord's Avatar
Default Re: Fuel injector service
Your local dealer needs to make money somehow!
What you are quoted for is an onboard injector flush. But if you're going to spend the money doing it, you might as well do it properly, and get a proper ultrasonic clean, spray pattern analysis etc. Here is a place that does a good job in Melbourne for example: https://www.efihardware.com/products...ector-Cleaning
Symptoms of blocked injectors are the usual flat spots / hesitations, misfiring and poor idle quality etc, but...there are so many other sources that can cause these exact symptoms.
Old 05-03-2017, 05:30 PM   #3
marg99
make sure its not cheaper to replace them first.
Old 05-03-2017, 06:23 PM   #4
Cheers guys
Tim.
There are some precautions you can take which will help alleviate any injector problems in the long term;
1. Run a bottle of quality Injector Cleaner through your fuel tank every 5,000 kms or so.
2. Run Shell V Power or BP Ultimate for it's cleaning properties if you can afford it over 91 or 95 RON.
3. Replace your fuel filter at regular intervals... At $20 or so each, its good insurance
4. Try to purchase fuel whenever possible from high traffic and newer servos with newer in ground tanks... Avoid filling up at low traffic small stations in rural areas where possible.
5. Don't overuse "Octane boosters" such as Nulon Pro Octane booster in your tank as they tend to leave a red / orange residue over time which can cause problems with injectors.
Old 05-03-2017, 06:34 PM   #5
RACERED
RACERED's Avatar
Yeah I have always run 98 octane from on the runs only. Never touched octane booster or fuel filters etc. Stock ST with only log book servicing.. nothing else done or replaced. May need to just get it done
