Old 15-08-2017, 08:38 PM   #1
bluebaboy
Default Help with brakes.
Hi all, wondering if any one can help me. Why am I not getting any fluid from abs to left front. Have bleed brakes and all others fine but nothing to front left. There is fluid getting to the abs but not down the hard line to FLeft. ????
bluebaboy is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2017, 05:14 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: Help with brakes.
You've not said what sort of vehicle but as a general answer you are looking at:
- a kink / brake / blockage in the line to the LHF;
- if it one of the later 4W ABS systems rather than the earlier 2W systems then you may actually have an (expensive) failure in the ABS module
Russ
Observatio Facta Rotae
