Old 06-02-2018, 07:07 PM   #1
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Default BA to FG towbar swap
Does anyone know if the towbar from a BA wagon will swap over to an FG?
The suppliers have them listed as the same part but just thought I'd ask before I get under there and find out the hard way.
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 06-02-2018, 07:38 PM   #2
78xcgxl
78xcgxl's Avatar
Default Re: BA to FG towbar swap
No. Wagon is different to sedans. BA to FGX sedan use the same towbar. AU to BF11 wagon use the same towbar. AU to FGX ute use the same towbar.
78xcgxl is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2018, 01:44 AM   #3
EBSXR6
EBSXR6's Avatar
[QUOTE=78xcgxl;6080363 BA to FGX sedan use the same towbar. [/QUOTE]
I have an FGII ECOLPI sedan and I had the towbar fitted at the dealer.
I am not sure what the difference is but there are different part numbers for the Petrol and ECOLPI models.
EBSXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2018, 06:28 AM   #4
commodorenutt
commodorenutt's Avatar
Gas has a different side leg, due to the rail differences for the tank mounts.
I got a BA one for my FG LPi.
LPi is the same towbar mounting arrangement as the e-gas towbar on BA-BF & earlier FGs (up to 10/2010 when e-gas was discontinued).
The only difference between the BA & FG ones that I found with mine, is the anti-rattle bolt that clears a BA/BF rear bar, fouls on the FG due to the different profile of the bar (it sits out firther from the body at the bottom where it fits around the towbar neck).
commodorenutt is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2018, 08:06 AM   #5
ebv8
ebv8's Avatar
also don't stress about cutting the hole in the bar, the bar has a template cast in so i just cut it our with a stanley knife after using a step drill for the corners
also there are no threads in the mounting holes so you are supposed to use self tapping bolts with a gun, i used a tap to make the threads as i didn't know this when i installed mine
and don't forget the loom that plugs into the right tail light, i made a loom but for the amount of work just buy one or get one from a wrecker
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
