Old 24-03-2018, 12:47 PM   #1
Vortex-98
Vortex-98's Avatar
Default AU reverse gear can't handle load
Hey guys I'm having a problem with my reverse gear ,,if I park it on a steep driveway it doesn't have enough power at normal revs to back it up ...an if I stomp a bit to hard on the pedal it sounds like it's either breaking traction or the reverse gear is slipping ...any idea what is going on with it,,that the diff would do this only in reverse..
The car is auto..
[B]WTB (Syd)...AU 5.0 or xr8 4 speed auto transmission in good working cond /B]
Vortex-98 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2018, 12:51 PM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Re: AU reverse gear can't handle load
Dont Fairmonts have traction control, i think they do?
cheers, Maka
Old 24-03-2018, 01:13 PM   #3
falconhell74
falconhell74's Avatar
sounds like the bands are slipping id have the trans serviced and adjusted
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2018, 01:17 PM   #4
raceteam
Check the fluid level in the trans before doing anything else.
raceteam is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2018, 10:36 PM   #5
Vortex-98
Vortex-98's Avatar
Ok thanks for the info , is the tranny dipstick under the bonnet?
Traction control maybe turned off, there's plenty of slip in the back tyres if u get my drift..
Old 24-03-2018, 11:40 PM   #6
Maka
Maka's Avatar
If theres some serious kays on the box, maybe do a service & check the filter for clutch plate debris.
Check the fluid level for now & if its good & your sure there was slippage, i would do the above then go from there, good luck!
cheers, Maka
Old 25-03-2018, 07:03 AM   #7
raceteam
No dipstick.
https://fordforums.com.au/vbportal/v...?articleid=556
It's on a Territory, but same trans, so you get the idea.
Old 26-03-2018, 09:29 PM   #8
Vortex-98
Vortex-98's Avatar
So to check the level of ATF in the tranny to be sure it has enough ,
how do I check the level an then how do I top it up????
Old 27-03-2018, 03:41 PM   #9
raceteam
The link I already put in tells you how, and has photos.
Old 27-03-2018, 03:57 PM   #10
Beastie
The Terrain Tamer
Beastie's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Catering services for a bunch of layabouts and for being an all-round good guy whose sense of community goes above and beyond.
As per the link, but a bit more info.
You can't check it.
The only thing you can do is pump more fluid into the tranny until it starts to come out of the hole you are filling it from.
Current Ride : A Ford owned D3...
Beastie is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2018, 04:26 PM   #11
Maka
Maka's Avatar
When the filler bolt is undone (after you've jacked the car up level), the fluid should be level with the bottom of the filler bolt thread. Plenty of old threads describing as such, good luck!
cheers, Maka
Old 27-03-2018, 05:39 PM   #12
falconhell74
Use a single hex socket , 9 times out of 10 this bolt is extremely tight and probably already half rounded from the last attempt , its a PITA
Xc falcon
Previous fords-
