![]() Join Date: Oct 2006
https://www.productsafety.gov.au/rec...focus-and-kuga - The clutch assembly may overheat as a result of excessive clutch slip. This condition could cause the clutch pressure plate to crack and/or fracture, which could damage the transmission assembly, allowing transmission fluid to leak.
regards Blue |
Mine is booked in for June 20 earliest date to get a loan car.
More good publicity for ford focus,Really dont they test there cars properly before releasing them ????????
You realise it is only manuals.
So few people buy them now and there is no manual available on the next (2019) model it doesn't matter really. |
#5 | |||
Anyone loyal to the brand would of chosen the manual version of the lz over the auto just to be safe from the pitfall of the dual clutch lw. so anyone that went the safe route has still been delivered a double blow of bad luck |
FGII XR6, Focus Sport, XR
Our LZ is Auto, knowing full well, that the last set up was a disaster.
We don't test these Focus's out at the proving ground, but knowing how hard and full on majority of testing is for each model lets me know they can handle a lot in terms of punishment. Ford also only gets a certain amount of models, so really if those couple of models make it through and then they begin failing in the field, it's just some bad luck, but at least Ford are recalling most issue........the LW auto issue was a disaster and really wasn't handled the way it should have been though.
Living Ford dreams
2011 Purple FGII XR6 2016 LZ Focus Sport BA XR8 Build Thread (SOLD) 1966 XR Falcon Build Thread |
So Ford has recalls for one off failures?
For Ford to do a recall, they need to know that it has a common occurrence and not just an anomaly. Every single person uses their car differently. If one car out of 75,000 has an issue, there are too many variables to put it down to vehicle fault. There would be limited data/information to narrow down any cause, and could even just be something that the owner has done. Every company would operate the same way. It would be a massive knee jerk reaction to recall every little issue, and would sink nearly every car company.
Living Ford dreams
So, the powershift gearbox was a rare occurance???
Dropped the car off today for the recall (it was getting serviced anyways).
This is how they got to the conclusion for the recall. https://static.nhtsa.gov/odi/rcl/201...8V169-5372.pdf Here are the details of what they're going to do for now in the interim. https://static.nhtsa.gov/odi/rcl/201...8V169-6865.pdf The service check is just this. A1 TEST CLUTCH SLIPPAGE Apply the parking brake. Start engine and engage 4th gear. Run the engine at approximately 2,000 rpm. Slowly release clutch pedal. Does the engine stall when the clutch pedal is fully released? Yes Clutch is OK. If there is a clutch slippage, you'll get a loan car in the meantime until it's resolved. |
The powershift issue doesn't seem rare at all.
I was talking of recalls in general.
Living Ford dreams
