Old 19-07-2018, 08:51 AM   #1
euro
Default Independent ford diesel specialist
Need some trouble shooting done on my sons TDCI Focus.
Who are the recognised ford independents specialising in diesels?
Melb eastern suburbs?
euro is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2018, 07:40 PM   #2
DeKa
Default Re: Independent ford diesel specialist
You can look for Peugeot specialists too - same engine as many Peugeots
This thread seems helpful:
http://www.aussiefrogs.com/forum/peu...ml#post1240560
DeKa is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2018, 09:04 AM   #3
euro
Thanks Deka,
Am a frogger (85fuego) and am aware of the engine sharing.
However, there may be an issue with the engine and may be throwing a fault code that is not being shown on the dash?
I suspect the diagnostic software used by the frogs may not be the same as used by the Ford franchise, hence the request.
My thoughts are that a indi specialising in small fords with the factory software will be the way to go other than apprentices at a big dealership?
Old 20-07-2018, 12:56 PM   #4
stefcio007
What year and what symptoms are you having?
2020.25 Focus SA ST-Line Wagon + DAP
2011 Focus LW Trend (Diesel) [sold]
2006 Territory SY Ghia (AWD)
stefcio007 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2018, 03:52 PM   #5
euro
Hi stefcio007,
2007 2L TDCI.
Sons car.
He says always hard to start on first attempt.
Always starts on second attempt.
Manifests itself during the colder months.
Less than 2 y.o. battery, good charge.
Fuel filter replaced 50k ago, will change next week.
Once I have changed fuel filter will check symptoms again.
May be glow plugs?
These are most likely not been replaced in its life.
Do dodgy plugs throw a CEL on the dash or is that issue one that doesn't have to?
Other than that looking for electronics/other that may be causing the issue.
Thanks
Old 20-07-2018, 04:02 PM   #6
stefcio007
Yep, sounds like a glow plug. Try turning the power on and waiting 30 seconds before starting.
Old 03-10-2018, 07:46 PM   #7
stefcio007
Did you find the issue?
Old 03-10-2018, 10:23 PM   #8
RadioactiveX
Diesel Motor
RadioactiveX's Avatar
Based in the manual, the glow plugs are kept turned on for 30 seconds after the engine started.
2011 Ford Focus TDCi 2.0L 6sp MT
RadioactiveX is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2018, 10:19 PM   #9
euro
Stefcio007,
No haven't diagnosed the issue.
Still think its the plugs.
Now we have warmer weather, problem not so much an issue.
Till next winter that is.
Do Ford provide a diagnostic service?
I assume the genuine Ford computer will advise non performing plugs?
