Old 27-06-2010, 03:51 PM   #241
sleeper393
sleeper393's Avatar
Question AU S/3 SWAY BARS sizes
ARE THERE ANY DIFFERENCE IN SWAY BAR DIAMETER FROM FORTE TO XR SERIES ON AU S/3's
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak!
AU SERIES 3 LIQUID SILVER
BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS
123.4 GROUND TEARING RWKW'S , LOL
sleeper393 is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 11:48 PM   #242
XLR8
BSR
XLR8's Avatar
Part number for chrome ring that sits under manual gear knob on t series?
FPV GT 725 with a few options including the stars........
XLR8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2010, 12:01 AM   #243
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
TAU2 7E097 A - SPACER GEAR LEVER
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2010, 02:07 PM   #244
Skeg37
Default Thanks to AFF and members
Since buying my AU XR6 I have managed to fix quite a few things myself and therefore saved a few dollars. The info on the forum is great. So far I have fixed
Power window button
Spanner symbol on dash
Brake pads
Door handle
Just need some tyres and I'll be on the road.
Thanks to all the posters!!
Skeg37 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2011, 03:32 PM   #245
Benn
Hi Russ,
I've tried the parts list, was wondering if it includes tail lights?
Benn is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2011, 06:08 PM   #246
russellw
Chairman & Administrator
russellw's Avatar
Search for them under LAMP ASSY
Russ
Observatio Facta Rotae
Old 21-01-2011, 06:34 PM   #247
Benn
yeah it isn't on there, it only has lights for AU2 and 3, i'm after AU1. its a long rectangle. don't know if that helps at all?
Old 21-01-2011, 10:26 PM   #248
russellw
russellw's Avatar
They are in there - there is no difference in tail lamp assemblies across all of AU -
Normal tail lamps -
ER 13404 A LAMP ASSY - REAR, RH, 4 DR SED, FORTE/FUTURA/"S"/XR
ER 13404 B LAMP ASSY - REAR, RH, 4 DR SED, FORTE/FUTURA/"S"/XR
ER 13405 A LAMP ASSY - REAR, LH, 4 DR SED, FORTE/FUTURA/"S"/XR
ER 13405 B LAMP ASSY - REAR, LH, 4 DR SED, FORTE/FUTURA/"S"/XR
Rear Spoiler Stop Lamp
AU1
ER 13A582 A LAMP ASSY - REAR, INCLUDES LAMP HARDWARE, FOR SPOILER, CENTRE, 4 DR SED, FORTE/FUTURA/"S"/XR
AU2
AU2 13A582 A LAMP ASSY - REAR, INCL. HARDWARE, CENTRE, 4 DR SED
High Mount Stop Lamp
ER 13A613 A LAMP REAR HI MOUNT, 4 DR SED, (-) XR
LTD TAIL LAMPS
LR 13404 A LAMP ASSY - REAR, RH, LTD
LR 13405 A LAMP ASSY - REAR, LH, LTD
FAIRLANE TAIL LAMPS
NR 13404 A LAMP ASSY - REAR, RH, FAIRLANE
NR 13405 A LAMP ASSY - REAR, LH, FAIRLANE
Russ
Old 23-02-2011, 07:40 PM   #249
FGII-XR6
FGII-XR6's Avatar
tried to find an AU (DU) LTD grille in the database but couldn't find it can you help?
[SIGPIC][/SIGPIC]
Rides:
Old 23-02-2011, 08:27 PM   #250
russellw
russellw's Avatar
As far as I know they are obsolete but the part number would be DU 8200 A or similar.
Russ
Old 23-02-2011, 08:57 PM   #251
FGII-XR6
FGII-XR6's Avatar
thank for that
[SIGPIC][/SIGPIC]
Rides:
Old 25-07-2017, 08:36 PM   #252
Edxr6
Default Re: AU Parts Data
Guy's,
Are the Silver trim that fits in the rebate of the front bars of the XR's still available.
Regards
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2019, 06:34 PM   #253
Are the repro AU1 bonnets (as in, those which fit an XR) all rubbish, or are there any worth looking at?
Don't fancy my chances of finding a clean Liquid Silver bonnet any time soon. Rust has destroyed the other one from the inside out, front lip and 3" back.
