Old 08-04-2006, 10:42 AM   #1
ltd
Force Fed Fords
ltd's Avatar
yes. Feel around the throttle body and push the butterfly actuator manually. If it has no restriction, then you know it's the cable. I'd also check around the top of the pedal for loose carpet, underlay etc, check that nothing there is binding too. Good Luck
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
