Old 15-04-2006, 04:27 PM   #1
Ozfords
Girls! Drink! ****! ****!
Ozfords's Avatar
Default How does that boot lip spoiler go on?
Hey guys silly question but, do I have to drill holes for that ED lip spolier to fit onto the boot?
Or can I just use tape or some adhesive, sounds like the lazy way out but the benefits of sticking on is more flexibility if I or the next owner want to remove it, no holes to worry about!
Or can I get someone to fit it professionally? Only because I'm a bit challeneged in that department and prone to effin it badly if I try fitting it myself. But who do I call to fit one of those bad boys!?
Automatic Driver and I'd be proud of that fact, only if I weren't so lazy.
1993 ED Fairmont Sedan - I6 - Colbalt Blue
- XH Snorkel
- Superlow Kings Springs and KYB Shocks
- Cross Drilled and Slotted DBA front Discs
- 18" pre-AU GT-P Alloy Wheels
- Ford Original Bootlid Spoiler
Ozfords is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2006, 04:52 PM   #2
Rmyers
Does Steve have a car?
Rmyers's Avatar
Well the standard XR* lip spoliers have bolts built into the rubber, so you can either drill holes on your bootlid or grind them off and use double sided tape/urethane
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2006, 10:58 AM   #3
AshMan
Girrrrr!!!
AshMan's Avatar
that urethane ИИИИ can be pretty hard to get off if its been there a long time...
You know the plastic windshield things they had on the drivers side door?
I had to sand that adhesive stuff back.
Personally I think in the long run it'd be easier to drill the holes and have to bog them up and paint later...
Falcon EF XR6 in Heritage Green
Heritage green, isn't that a fence paint?
AshMan is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2006, 08:42 PM   #4
sven
sven's Avatar
i'd agree, urethane rips off paint if its been there a while. my 4.0i badge on the quarter panel was stuck on with that **** and ripped off all the paint!! bolt it on.
ED XR8
sven is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2006, 09:32 PM   #5
EDXR6T
na screw putting hole's in to it
if you'r wurry'd aboout re painting
you'r going to have to re spray it any way wen u go to Bog the hole's up
so just go the urethane
pluse u'll need some sort of seal so u dont have water getting in and russting any thing out
p.s i wouldent b boging the hole's neather i'd b taking them up:S
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
