#31 | ||
go to your local council transfer station, they will give you dozens if you want them
I reserve the right to arm bears
#32 | ||
Cabover nut
Agreed, thats where the ex veggie oil containers I'm given get left.
#33 | |||
Peter Car
#34 | |||
https://www.flotool.com/drain.html |
#35 | |||
Former BTIKD
![]() Join Date: Mar 2005
#36 | |||
Cabover nut
#38 | |||
![]() In a perfect world, you'd drain exactly 5 litres of oil, pour in a full container of new oil, then pour the old stuff into the empty. (Obviously when things don't perfectly align, you'll need to improvise in the short term) In point of fact since most cars will burn at least a little oil over time, you will ultimately need to dispose of less oil than you buy. Plus, if you dispose of your oil by pouring into a communal drum, then you'll have plenty of empties. Besides, the combo pan&bottles featured above, aren't a substitute for an empty, as you still need to decant the old oil. |
#39 | ||
Regular...with metamusal
![]() Join Date: Oct 2009
i use the old school style [?] which you place under engine, let oil drain into it & then carefully drain the oil back into the container which had the new oil in it. mine have the small open funnel as a pour spout which to me is the only drawback. as has already been mentioned ..... reuse, recycle
#40 | |||
![]() Or alternatively miss the oil pan and dump half of it on the driveway, thats also one of my favorite tricks. |
#41 | ||
