Old 28-01-2012, 11:51 PM   #1
Matwilliams91
Matwilliams91's Avatar
Default Hot rod chassis
Where would one find the chassis dimensions for a 1928 - 32 Ford? I'm starting a hot rod project, and am looking at making mostly everything myself, chassis included. I'm just after the dimensions so I can start work.
It will be a little "different" to any out there, my plans are to heavily modify the chassis for my plan to work...
I'll keep you updated, obviously in a different section.
So where's the best place to look?
Matwilliams91 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 12:05 AM   #2
Kryton
Kryton's Avatar
Default Re: Hot rod chassis
Google for a start.
American Stamping
8719 Caroma,
Olive Branch, MS
38654
tel : (662) 895-5300
or email Michelle @ jutbl@msn.com
** put '32 rail prints in subject line. drawings are $10 USD
This info was in the June 2003 issue of StreetRodder, pg.196
http://www.ebay.com/sch/i.html?_nkw=1932+ford+frame
Old 29-01-2012, 12:21 AM   #3
XR Martin
XR Martin's Avatar
Are you going to want to register it?
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 12:23 AM   #4
Matwilliams91
I am, will this be a problem?
If it is, chassis mods may not be done, will it still be a problem?
Sorry for the questions, its my first build of anything major apart from a Group NC Torana.
Old 29-01-2012, 12:24 AM   #5
Matwilliams91
Originally Posted by davway
Google for a start.
American Stamping
8719 Caroma,
Olive Branch, MS
38654
Cheers, will look into it.
Old 29-01-2012, 05:33 AM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
My mates 32 sits on a Hi Lux chassis , not sure if that's a route you wish to take or not.
Originally Posted by Riksta
Old 29-01-2012, 07:43 AM   #7
2011G6E
2011G6E's Avatar
'32 rails are curved and sculpted...not exactly a make-it-at-home proposition like a Model T chassis is (that's basically some straight rectangular section that anyone could knockup).
Plenty of kits available though, and I have seen ones that are side rails and cross rails which you'd have to weld together...but you'd want to make sure you did it right. I'd be buying a chassis and going from there...
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 10:07 AM   #8
Turboconvert
Check out ozrodders.com
They are an australian hotrod forum. very friendly guys. They will be able to answer all your hot rodding questions. Especially chassie wise
also check out http://www.asrf.org.au/
That site will also guide you as to what mods will be acceptable for street registration. If it doesnt match their requirements, dont expect to registor it, period. Assuming that is the direction you want to take. Otherwise if it is to be a drag car or show car ownly, check out cams, otherwise, mod away
I want to make my own rod one day but given my current financial situation it is a little to expensive at the moment. So I am starting with a more reasonable base (ie cheaper to start of with).
Bf xr6 turbo sedan, 6 SP auto, Leather/suede interior
Turboconvert is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 10:31 AM   #9
Jim Goose
If you intend registering it, hope you have done your homework and checked with your relevent roads authority.
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 10:37 AM   #10
302 XC
Depending what your trying to acheive at the end, the original rail dimensions mite be of no use whatso ever
Most who qualify for full rod rego start with an original chassis and mod that as it qualifies as a pre 1949
So a few questions, full rego or rod rego ,can you not use a later model chassis as a donor and go down the rebody path
Are you goin for an authentic style or look , or will later model style suspension not bother you
ozrodders is a good site,theres plenty of yank sites,theres plenty of info out there on 28-32 fords
302 XC is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 11:04 AM   #11
Elks
Elks's Avatar
As Uteaddict says, ASRF is the answer. Join it, you will have the resources and contacts to do it the right way if you want to get it registered.
SR "street rod" registration under the permit scheme is pretty flexible, almost sane, but you must work with the authorities using the scheme. Working against will end in tears.
32 rail would be hard to replicate. It would be better to buy a pair of reproduction rails and add your own cross-members and suspension points to these. It would also help with registration down the track.
My 2c
Oooh baby living in Miami....
Elks is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 12:35 PM   #12
Pub247
Resident F1 Troll
Pub247's Avatar
rails arent that hard to replicate with the right equipment you can always pay someone with a ring roller to rool the rails for you
Pub247 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 12:51 PM   #13
Turboconvert
Like Elks said, if you intend on doing a hot rod, it is just as easy to buy reproduction rails. And then add your own cross members, suspention components and the like. Plenty around the joint, especially for a budget of about 5-6 grand or under if i remember correctly.
http://www.rodbods.com.au/
http://www.deucecustoms.com.au/index.html
http://www.cruzin.com.au/ (australian hot rod mag, there is also australian street rodding but cant find the site)
Becarefull when viewing american hot rod sites. There are somethings that american hot rod builders can get away with that you can't in Australia. This comes down to different legislation basicly. Anyways, enjoy
Old 29-01-2012, 04:33 PM   #14
atec77
Contact the Asrf and get a copy of the rules for your state , there are two real choices , buy the body and drop it on something like a lux which means certain engine capacity restraints when registering as a lux or join your local club who will find an engineer to assist and guide you through building a real rod , doing either build has limitations but the last rod I built was a 1948 Austin A40 clevo powered delivery van which was registered here in Qld as an individual construct , the new owner wrote it off :( which was a waste of 3 long hard years of work and a great deal of money , good luck in your decissions and have fun
atec77 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 07:03 PM   #15
JG67k
Im pretty sure only SA can make youre own chassis rail's most other
state's you need original rail's plus at least 2 original crossmember's
used to get reg , deffinately join OZRODDER's there's some talented
guy's on there .
ASRF is the only way to go to get rego .
JG67k is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 08:38 PM   #16
Matwilliams91
Thanks for all your assistance fellas.
I'll keep looking into things, and see how I go.
Will definitely be using this advice.
Thanks again
Old 29-01-2012, 09:15 PM   #17
JG67k
Unfortunately putting a rod on a lux chassis is not that easy,they are
changing the rule's , where the donor body must comply with the chassis
original crash test and ADR spec's .Join a club first , someone there will
have built simular and can help you thru it.
Old 29-01-2012, 10:56 PM   #18
ebxr8240
Performance moderator
ebxr8240's Avatar
There was an episode on Overhauling where they fitted a new
chassis ....
Daily driver GTE FG..
Old 13-03-2022, 03:01 PM   #19
vaxx
You can always go this way.
'02 Hilux running a 302 auto
vaxx is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2022, 03:47 PM   #20
Bossxr8
Peter Car
Bossxr8's Avatar
Might have been useful 10 years ago when this thread was started.
Old 13-03-2022, 09:40 PM   #21
Warrenk
Warrenk's Avatar
This thread from 2012 is probably not relevant any more.
Never argue with an idiot, they will bring you down to their level and beat with experience every time.
Warrenk is online now   Reply With Quote Multi-Quote with this Post
