Furious Performance
Old 10-04-2022, 09:31 PM   #1
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
Default Recommended tuners in Perth?
Asked this in the ECU forum but no one has answered it yet: https://fordforums.com.au/showthread.php?t=11493617
Can someone recommend a good tuner in Perth for my 220kW AU please? I've just rebuilt the top end: ported the GT40P heads, new (bigger) Crow cam, bumped the compression 1/4 point, Hurricane headers etc.
Got the engine running and seems to go hard, but I'd like to get it flash tuned on a rolling dyno. Cheers.
408 Charger 5spd - 11.666@121mph /\:T:/\ AUII XR8 Rebel - 220kW auto
Chrysler is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2022, 10:53 PM   #2
willo56
willo56's Avatar
Default Re: Recommended tuners in Perth?
Hey mate
Can't comment on the AU specifically but I'd try either Monstatorque or Xtreme Ford Tuning for anything ford related in Perth as a starting point
Sent from my moto g(7) using Tapatalk
Current : 2017 Holden SS-V Redline W375
Previous :
1970 XYGT 351 Replica
1975 Falcon XBGS
1979 XD Fairmont Ghia 351
1982 XE Falcon Panelvan
1986 XF Falcon Ute
1988 EA Falcon
1995 EF Falcon
1997 Ford Explorer XLT
2004 BA Falcon
2008 FG Falcon XR6 Turbo
2008 HSV VE Clubsport LS3
2008 Holden VE SS-V Ute
2011 FPV FG GT 335 #329
2013 Holden VF SS W310
2014 Holden VF SS-V Ute
2013 Holden WN Caprice V
willo56 is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2022, 12:00 AM   #3
XFISH98
XFISH98's Avatar
As @willo56 stated, monsta torque are highly rated.
https://www.monstatorque.com.au/?msc...9bdf4526686ffe
XFISH98 is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2022, 02:07 PM   #4
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
Thanks for the tips guys. Unfortunately Monsta Torque doesn't do Windsor V8s – only Barras and the later model overhead cammed V8s.
I'll make a few more calls . . .
Old 12-04-2022, 03:55 PM   #5
bungarra
Windsor V8's, you're better off trying these guys lerace Automotive. Windsor Specialists. Seen lots of good work from budget to high end work. Sorted out my XR8.
https://www.ieraceperformance.com.au/
bungarra is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2022, 08:06 PM   #6
MrEL
Sick Puppy
MrEL's Avatar
Are Streetbuilt still in the game?
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2022, 11:53 PM   #7
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
Cheers mate. I'll give IErace a call tomorrow.
I did speak to a few dyno places today and the only one that said it could tune my Windsor was BPT: https://www.bptmotorsport.com.au/
They said they had loads of AU Windsor base tunes and a flash tune would cost $850-$1200.
I called Xtreme Ford Tuning but no-one seemed able to help.
I also emailed BPR in Victoria to see if they had a base tune they could supply to Monsta Torque to get them going as otherwise I'd be up for $250 an hour – and it was like the old "how long is a pice of string" equation as to how long it would take to tune starting from scratch.
I don't need to wring every last horsepower out of it, I just want a stable tune to idle and run the new cam and headwork efficiently.
Old 13-04-2022, 01:27 AM   #8
Venomous1
5.0 means business
Venomous1's Avatar
Had my Ute Tuned at BPT last year come up mint. Runs like a beaut.
Just has full exhaust and was running a bit crappy. Tuned it runs well and sounds mint.
Paid $1200.
Windsor V8 Enthusiast!
Turbo Barra Lover!
Venomous1 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2022, 02:35 PM   #9
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
Spoke to IERace but they don't have a chassis dyno. They suggested Xtreme Ford Tuning.
So far it looks like BPT is the only place prepared to come to the party.
Old 13-04-2022, 04:51 PM   #10
Venomous1
5.0 means business
Venomous1's Avatar
I'll add a bit more of my two cents.. I previously had my ute tuned by Streetbuilt.
But I found that the tune was a bit on the lean side. I rode with that tune for about 4 years.
I had a slightly leaky Gasket on a Header so I got BPT to change the gaskets and while I was there we discussed some of the running etc so we agreed chuck it on the dyno and lets see what its going like.
Very professional nice dyno set up too ran the car about 8 runs or so and I was smiling each run was making a little more HP. When we were done said take it for a test drive before I pay and I did that's when I realized what I had been driving for 4 years wasn't even that great and this ran so much better.
Windsor's don't have to much free HP they are already pretty much peak from factory but smoothing out the power and gaining more torque everywhere is indeed what changes alot about the car. Full exhaust helps alot tho especially higher flowing cats.
But that aside there is still alot to gain. Fuel Consumtion is better too.
I say give it a go and let us all be updated if you do.
Turbo Barra Lover!
Old 16-04-2022, 02:14 PM   #11
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
If you decide to go with BPT be very careful and cautious.
Make sure you get a detailed, written quote before the car is handed over.
Also stipulate that you are to be contacted, quoted and must authorize any other work that maybe required.
It could get quite costly otherwise and your car will be held in lieu of payment.
Feel free to drop me a PM if you have any questions.
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 16-04-2022, 02:35 PM   #12
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
OK, thanks. I appreciate the heads-up. I've already had a bad experience with the heads on the car when the machinists didn't heed my instructions and assumed they knew better than me (they didn't) when converting to a set of LS beehive springs. It got a bit messy, though at least they owned their mistakes in the end and we salvaged the heads with a set of spring locators.
I will drop you a PM.
Unfortunately at this juncture BPT is the only tuner to come to the party, so it looks like I don't have many options.
On a happier note, the car is running after a one-year rebuild and I'm really happy with the engine, even though she's running a bit lean now with the new cam and head work.
http://www.fordforums.com.au/showthread.php?t=11489593
Old 16-04-2022, 02:46 PM   #13
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
For my exhaust I'm running Hurricane Headers with 2.5" collectors into 2.5" hi-flow cats, and then the system steps down to a twin 2.25" system with H-pipe and Redback mufflers. Sounds pretty good and seems to go OK.
Old 16-04-2022, 02:56 PM   #14
ivorya
Mad Scientist!
ivorya's Avatar
WHo does the circle D transmissions over in Perth?
Is it Bluestreak performance? Daniel?
He used to always have converstations on here with Xtreme Ford Tuning.(Simon?)
Yrs ago, he had a monster worked TE50 i believe. https://fordforums.com.au/showthread.php?t=11195321
If anything, a message or a call. He maybe able to point you in the right direction.
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2022, 03:58 PM   #15
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
Nice build but that's not a Windsor – and that is my problem. Trying to find someone who can tune my Windsor. Everyone seems to only do Barras and overhead cammed V8s these days. Windsor's aren't rocket science, so I'm not sure why it's so hard.
Old 17-04-2022, 08:19 AM   #16
ivorya
Mad Scientist!
ivorya's Avatar
He went to the terminator after he'd maxed his windsor.
Anyways, you could also try a piggy back. ie/ unichip. I'm sure there are a few dealers/tuners in WA
Old 18-04-2022, 02:07 PM   #17
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
Thanks for clearing that up mate.
And thanks for the heads-up on the Unichip - I'll have a read through it and educate myself. It might be a better way to go.
Whilst searching for Unichip dealers in WA I found this mob: https://www.ecuwest.com.au/ecuwest-d...ecu-remapping/
Any ideas about them?
Old 18-04-2022, 02:53 PM   #18
Mulva
How about the place that tuned this guy's car so well that it went 4-times faster than he expected and it was tuner's fault that he got clocked at over 240km/h
https://www.fordforums.com.au/showthread.php?t=11492287
Mulva is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2022, 03:32 PM   #19
ivorya
Mad Scientist!
ivorya's Avatar
ALso while researching, have a look at Haltech as well.
Old 18-04-2022, 09:57 PM   #20
GTENVY
GTENVY's Avatar
Hey Chrysler,
Streetbuilt have shut shop unfortunately, I had my previous XR8 Sprint built through them and they did great work. I've spoken to XFT and they don't do Windsor anymore and have been finding the same problem you are finding here in Perth.
I have been dealing with BPR myself in getting my ECU flashed for manual - I'll PM you with info.
BPT for me the jury is out, lots of stories from both sides. Let me know how you go.
Rich
FM Mustang GT, manual - Daily driven
Live, Love, RACE
SOLD: AU III XR8
Originally Posted by nstg8a
cars are to be driven, ornaments are to be looked at. the two should never be confused.
GTENVY is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2022, 01:33 AM   #21
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
Ah, a tuner is now the least of my worries. I just punted a tow ball taking the car for its first official cruise down south when I hit someone who suddenly slammed on their brakes when we both took off from a green light.
Fark!@ Anyone have a spare AU XR nose cone or knows a really, really good plastic welder???
Old 20-04-2022, 09:50 AM   #22
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
A good friend of mine is a bumper repairer, he used to run Bumper exchange here in Perth, he lives in Mount pleasant and does the occasional bumper at home, send me a Pm if interested and ill pass on his number.
Old 20-04-2022, 09:54 AM   #23
Hmm… IIJM or do you think the reo will be munted?
Dash cam might be a good investment.
Old 20-04-2022, 11:56 AM   #24
Tratado Injustamente
Buy a car tuned properly to start with and no need to use backyard tuners "more power bro"
Tratado Injustamente is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2022, 01:00 PM   #25
Bossxr8
Peter Car
Bossxr8's Avatar
Huh?
Did you miss the part where he said he needs a retune to suit the new cam he has fitted?
Old 20-04-2022, 01:05 PM   #26
DJM83
Barra Turbo > V8
DJM83's Avatar
Originally Posted by Bossxr8 View Post
Huh?
Was thinking the same thing.
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
-2022 Hyundai Tucson Highlander Diesel N Line
Old 22-04-2022, 02:41 PM   #27
So two people clearly didn't get the point i was making.
Who is "thinking" again?
Old 22-04-2022, 03:18 PM   #28
FairmontGS
WT GT
FairmontGS's Avatar
New user account... same old attitude...
FairmontGS is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2022, 03:24 PM   #29
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Asperger’s ?
Old 22-04-2022, 03:39 PM   #30
Originally Posted by prktkljokr View Post
Asperger’s ?
Do you? Sorry to hear that.
