Hi all < New to the forum , i have recently bought a 2000 NU fairlane Ghia V8 , PO had cut holes in the bonnet , i want to replace it with a bonnet with the Bulge . Can this be done without too much work or better still , straight swap . Thanks Mark
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
do you mean this ?
https://www.ssv.com.au/bulge-bonnet-...airmont-falcon
Hi . Yes thats what had in mind ? Would that be a direct bolt on or any mods needed .thanks mark
I would say probably no, HOWEVER I would call the guys on that website to confirm you can. (Edited for future questions.)
How did you get on?
#neuteredlyfe
![]() ![]() Join Date: Apr 2012
I think that what you are essentially asking is if the Falcon bonnet will fit a Fairlane? If so, then no the Falcon bonnet will not a Fairlane.
If you are asking if the bulge itself will bolt on easily then sorry, the answer to this is also no. I am sure that you could do it, but it would not be as easy as bolting it straight on. |
Thanks for the message , will do more research
Former BTIKD
![]() Join Date: Mar 2005
looks like a no fit to me, Thanks mate.
