28-04-2006, 05:35 PM | #1 | ||
All Bran = Regular Member
if the gods are with me I'll fit up my new suspension this weekendnd (AUIII Fairmont Ghia).
I'm fitting AU XR coils and as yet nameless front and rear shocks (I pick them up tomorrow). As it is a long weekend up here I'm a bit concerned about needing to buy something from Ford and having to wait till Tuesday. Can anyone who has a clue on this suspension advise me if there are bits that I should replace (other than the coils and shocks). The only thing I can think of is bump stops if needed but I don't know what else *may* be req? Cars done around 100,000kms. Thanks... |
28-04-2006, 06:04 PM | #2 | ||
I'm fitting King Lows and Monro GT Gas tomorrow. Wouldn't mind knowing the same things.
28-04-2006, 06:09 PM | #3 | ||
AnArChIst
well i did my EF which had 160,000kms with new king springs and monroe shocks/struts, and didnt need to replace anything else.....you can get to everythign else latter on if you have too
If you can stay calm, while all around you is chaos...then you probably haven't completely understood the seriousness of the situation.......... I6 Assassin |
28-04-2006, 06:19 PM | #4 | ||
A mate and I did the front on the wife's AU wagon a couple of weeks ago. Using a rattle gun made it a little easier, and both the front shocks and springs took under an hour. Also decided to bleed the brakes at the same time.
Current Rides: 2000 AU 5L XLS ute; 1970 Mustang project |
28-04-2006, 06:31 PM | #5 | ||
All you need is shocks and springs, some large sockets and spanners, and a tapometer. That's about it.
28-04-2006, 06:44 PM | #6 | ||
buickman
On the AU ghia IRS you will need to remove the rear caliper bolts to push to one side so as to remove to rear struts while you are at check the upper rubber mounts.
On the front you will need a 18mm socket or spanner to undo the top ball joint nut so you can remove the front strut. Everything else is straight forward in removing & replacing |
29-04-2006, 06:07 AM | #7 | ||
I put in XR coils on my Series 1 Forte (100 000km) and ever since have had a rattle in the rear end. I thought it was the shockies so I recently replaced them and it is still there.
What I think it is are the rubber caps that sit on top of the coils (sort of screw in for one and a bit turns). Maybe the originals rubber caps are slightly larger than the XR coils and therefore a bit loose. I have checked all components and everything is as tight as it should be. Even used a torque wrench. Anyone have ideas on this problem? I'm going to chase up to see if the XR coils do need their own rubber caps. Also have to check the bump stops as the new shockies never came with them. Good luck with it |
29-04-2006, 09:09 AM | #8 | ||
buickman
Ronwest car has the IRS being a ghia & he should check the rubber caps while he has the struts out
Fitting the XR springs of a none VCT XR to a Forte should not occure any real problems as they both run the watts link rear suspension but since you have checked shocker height & tightened every thing up. The only thing is the rubber caps or exhaust or someother item slightly touching. |
29-04-2006, 09:59 AM | #9 | |||
Are the rubber caps likely to be available aftermarket...Autopro etc? |
29-04-2006, 10:36 AM | #10 | ||
Check to see if the caps when placed on the XR coils are a snug fit. I vaguely remember mine being a bit loose.
29-04-2006, 04:21 PM | #11 | ||
Dropped into the local pedders store and asked a few questions.
They reckon the only places rattles should generate from are loose lower shock mounting points; the insulator caps that sit on top of the coil or the exhaust system ( as a result of the car sitting lower). Also, the Forte insulator caps can fit right onto the XR coil and the forte bump stops can also be reused if still in good nick. So I went home, put the car on stands, took the wheels off and rechecked everything. The rubber insulator caps were on correctly so all I did was extra tighten the lower shock mounts and voila, rattles gone. Went for test drive and everything is sweet. What I thought was tight for the lower shockies was obviously not tight enough! |
29-04-2006, 07:07 PM | #12 | |||
buickman
30-04-2006, 01:43 PM | #13 | |||
