Yesterday, 06:35 PM | #1 | ||
since i had a job done on back wheel that required pulling the axle I've had a bit of a whine in the diff.
Could be a problem? Or just live with it, it's okay? |
Yesterday, 06:54 PM | #2 | ||
Gear oil is better, the alcohol in wine will turn acidic and ruin your bearings.
It’s not hard to pop the back cover off and inspect the gears - why not do that for peace of mind? |
Yesterday, 07:30 PM | #3 | |||
'whine' isn't really the word, either. but I don't know what is. i can just hear it is the thing where I never could before. makes a sound like something turning, how's that for a description..? |
Yesterday, 08:02 PM | #4 | |||
Regular...with metamusal
yes there is a lot of whining.... from the diff. have at least 3 here that love a good wine.. thirsty work too. 1- Should there be oil in there or grease? ~ if there is grease .. at least it's lubed up ..... oil only and the correct spec. 2- How much? ~ hopefully you emptied what was in there & topped it back up thru the filler whole.. 3- Any slack to be observed/checked for anywhere? ~ there will be some slack ..... but not too much. too much and it's stuffed 4- I suppose a bit obvious thing is chipped or broken teeth but I'd expect more than a 'whine' from that ~ and that you would. 5- did anyone checkout the bearing whilst removed? 6- i can just hear it is the thing where I never could before. makes a sound like something turning, how's that for a description..? ~ sounds good to the deaf bastaard over hear.... grass is getting a bit long in ya paddock cheers St James |
Yesterday, 08:35 PM | #5 | ||
Perhaps it was previously filled with 140W and now it’s 85W/90 or something?
Yesterday, 09:36 PM | #6 | ||
Experienced Member
I would replace the diff oil and make sure it is at correct level; you could also add a diff additive such as Penrite Shift Eze Gearbox & Differential Treatment or Rislone Axle and Differential Gear Repair.
Today, 10:33 AM | #7 | ||
HSV - I just ate one!
Was the wheel bearing replaced when the shaft was pulled?
