Old 13-02-2025, 06:10 AM   #1
Default JH Cruze 1.8 Knock
Have picked up a cheap 2014 auto Cruze with 105K, contrary to most advice offered.
Terrible knock from it, haven’t had a chance to put in the air yet.
Is there any specific element to look at, or is it just run-of-the-mill diagnosis?
Old 13-02-2025, 07:08 AM   #2
smoo
smoo's Avatar
Default Re: JH Cruze 1.8 Knock
Engine knock, suspension knock?
How cheap is cheap CB… Risky investment?? Might strike it lucky and find an old Bintang bogan who’ll buy it for his Mrs and park it in the garage next to his VZ SV6 with HRT seat covers and fake HSV body kit.
smoo is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2025, 08:22 AM   #3
lra
Do you have a good collection of AccaDacca CDs. ?
lra is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2025, 08:34 AM   #4
roKWiz
Cabover nut
roKWiz's Avatar
For all the Cruze owners out there.
sorry CB.
Old 13-02-2025, 08:56 AM   #5
Actually, yes!
Old 13-02-2025, 09:42 AM   #6
Cav
HUGH JARSE
Cav's Avatar
Have you checked the boot?
Cav is offline   Reply With Quote Multi-Quote with this Post
6 users like this post:
Old 13-02-2025, 09:55 AM   #7
Good point; no!
Old 13-02-2025, 12:52 PM   #8
lra
Play them at volume setting 11, problem gone.
Old 13-02-2025, 04:15 PM   #9
Post of the day!
Old 13-02-2025, 09:40 PM   #10
$500, five months’ non-concessional registration, clean PPSR, good black leather. Cold AC, a few bruises, but nearly full of petrol too.
No oil on the dipstick, I’m tipping a holed sump or stripped and lost sump plug.
Old 13-02-2025, 10:47 PM   #11
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Worth more in parts, couldn't get a grille or a front bumper for one a few months back, paid $500 for a bumper in the end.
Old 14-02-2025, 07:30 AM   #12
lra
"No oil on the dipstick, I’m tipping a holed sump or stripped and lost sump plug."
I'm tipping the previous owner had no idea.
I have a son like that. Years he blew the clutch in his 4WD, and I had to go rescue him.
Out of curiosity, pulled the dipstick out and not smidgen of oil on it, I must be not seeing things, did it a few times, same result. He had never checked it in over a year. Told him he as lucky just to blow the clutch and not the engine. How does this happen.
Old 14-02-2025, 07:43 AM   #13
Previous owner was fully imported, no speak Ingris. So you may be right. They certainly struggled to know the position of the car relative to minor obstacles.
Old 14-02-2025, 08:38 AM   #14
roKWiz
Cabover nut
roKWiz's Avatar
Seems Ok for what it is.
I don't understand why just because you don't speak our language, you don't know how to park, put oil in an engine, get on a bus, get on a train, buy a ticket.etc etc.
Old 14-02-2025, 08:51 AM   #15
I can only assume that in other countries, the social cachet of car ownership brought with it starry-eyed lackeys hoping to elevate themselves by association. Those people being the ones who checked or repaired stuff…
Old 14-02-2025, 01:30 PM   #16
danzvtil
danzvtil's Avatar
When my company had 1.8 Cruze fleet, one of them just used oil from new (mine) if not topped up between services it would have run dry. Maybe this is the case here. And coolant, they all went thru coolant even from new.
____________________
2024 TOYOTA HIACE
2019 LDV G10-GONE THANKFULLY
2009 Mitsubishi Express-GONE
2011 Honda Jazz
danzvtil is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2025, 07:01 PM   #17
There is definitely an oil leak near the bottom front of the block, seemingly when running.
Sump is sound. There is no oil slinging so it’s not a crank/damper/seal issue.
I plan to hoist it on Sunday and see what gives.
Who’s cheapest for cheap oil? Coles allegedly have 15/40 at $28 per four litres. 10/40 might be better for seeing where it comes out.
Old 14-02-2025, 07:39 PM   #18
smoo
smoo's Avatar
Supercheap currently have Gulf Western on special 15 40 five litres for $20.
Old 16-02-2025, 10:04 AM   #19
Cam timing is well out, explaining the engine light and stored codes, but all compression is good - 200-250PSI. So the head is fine. I’m half thinking the oil leaks are camshaft seals. The lower part of the cam cover seems to do a good job of stopping oil from slinging much - hence my earlier misapprehensions about where oil was coming from.
I’d have expected low oil pressure to be stored as a fault code?
Old 16-02-2025, 12:35 PM   #20
Number 4 main bearing cap and journal. Almost new. No wear or any marks - can still see factory machining on the bearing metal.
Number 2 isn’t much different. A couple of lines so fine you can’t feel them with a fingernail (and as some here may observe, I have a decent supply of fingernail today).
Looking at the location of the oil filter/cooler setup, I believe it feeds the rearmost bearings first. Obviously I won’t disturb 5, as that would impact the rear main seal.
Old 16-02-2025, 05:39 PM   #21
OneMadMan
You can't fix stupid
OneMadMan's Avatar
Is the knock at engine speed or half engine speed?
I have heard valve guides make serious 'let's replace the lump' kind of noises...
Harmonic balancer lose?
Cam wheel(s) lose?
Deep knock?
Light metallic knock.
Bit late to ask for a video now.. obviously.
Just saying..
HSV, I've stopped trying to beat one (cause they've all been stolen)
Current ride:
2007 TRD Aurion 3500s 128,000 Kays and climbing
OneMadMan is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2025, 09:59 PM   #22
I think it’s a variator knock. Random journal shown here - being 4.
Again, the shells are good, no heavy grooves or major discolouration to the journals. The cap pictured has some scuffs in the shell seat I initially wondered about, but decided they were irrelevant.
I pushed each piston to the top of its bore in turn, felt for pin slop, then pulled back down and reassembled. As the bottom end uses stretch fasteners, I’m up for eight rod bolts and four main cap bolts. Plus another tube of Ultra Black RTV.
The sump had only debris I’d equate with manufacture. Sump plug is fairly stripped.
Old 17-02-2025, 01:06 AM   #23
smoo
smoo's Avatar
Conduct an experiment and save some cash.
Run the cap bolts again…
Old 17-02-2025, 01:54 AM   #24
It’s all together and driving again, I did recycle the bolts for now.
Old 17-02-2025, 09:18 AM   #25
Who is good (reliable and sensibly priced) for Holden/GM parts at the moment? Mainly to order relevant bolts.
Old 17-02-2025, 09:40 AM   #26
lra
Holden service centres still exist, AKA AC/Delco, and sometimes are cheaper than other outlets.
Old 17-02-2025, 09:56 AM   #27
Indeed - I’d wondered about Sutton’s, as it’s reasonably close - haven’t checked how sharp their pencil is, though.
Old 17-02-2025, 10:27 AM   #28
OneMadMan
OneMadMan's Avatar
Fun fact:
As far as I know, the whole reason they use Torque to yield bolts is to maintain the same tension upon reassembly in any condition, in any workshop, in any climate in the world.
Eliminating the torque wrench as the problem for over / under tightening.
I have reused bolts without problems. If it works, any your not planing on entering Bathurst, leave it be.
Current ride:
Old 18-02-2025, 11:02 AM   #29
Provisionally sold subject to a successful repair, first looker. Tidy interior, low km and honest exterior were the clinchers. I’ve literally put it back together unrepaired and sat it on the street to achieve that result.
Old 18-02-2025, 01:35 PM   #30
OneMadMan
OneMadMan's Avatar
yeah but, did you fix the knock?
Current ride:
