Old 01-03-2025, 01:01 PM   #1
T3rminator
T3rminator's Avatar
Default Oversized fuel pump and affects on performance
Got a general question. Can having a higher flow fuel pump affect performance?
I've got a 5.4L 3v, its done 320,000kms. The original fuel pump is 90LPH.
I replaced it with a delphi xr8 fuel pump, which flows at 150LPH.
I've noticed that from idle to about 3500RPM, the car has picked up a lot of go. BUT.....at wide open throttle, it doesn't seem to go as hard as the stock fuel pump.
The car was originally tuned on the stock fuel pump.
Is it in my head or can an oversized fuel pump affect top end performance? Do I need to go get a touch up tune done?
Car still runs the same regulator.
Rides (past and present)
Old 01-03-2025, 02:34 PM   #2
Interceptor
HSV - I just ate one!
Interceptor's Avatar
Default Re: Oversized fuel pump and affects on performance
There shouldnt be any difference in performance, just more fuel going back though the return line.
It'd be interesting to see what the AFR's are line when it gets dyno'd
Old 01-03-2025, 03:19 PM   #3
39ClevoUte
39ClevoUte's Avatar
I saw an instance where the fuel in the tank was boiling. We put a cooler in the return line which "fixed" it. We assume that the volume of fuel being forced through the small regulator orrifice was causing friction and heating the fuel? Interested in anyone elses experience.
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2025, 03:17 PM   #4
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
My fairlane had a carb and high flow fuel pump with 12 lines. Great for drag racing but driving it on the street for 30 mins and the fuel got very hot.
I wouldn't mind betting in this case that the new fuel pump might be delivering fuel at a higher pressure compared to the old one and that has thrown the tune out.
I think a run on a dyno would be a good idea
I love Holdens....
cs123 is offline   Reply With Quote Multi-Quote with this Post
