Old 28-03-2025, 07:52 PM   #1
daryle
Old drag racer
Default Aluminum inner panels
Just wondering if the use of aluminum inners were allowed on the 6 outer panels back in the day? Talking from memory XB onwards.
daryle is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2025, 08:24 PM   #2
Interceptor
HSV - I just ate one!
Interceptor's Avatar
Default Re: Aluminum inner panels
aluminium inners?
Interceptor is online now   Reply With Quote Multi-Quote with this Post
Old 29-03-2025, 07:36 AM   #3
daryle
Old drag racer
We were required to run some aluminum inner panels for Ford racing back in the day. The inners were for the 4 doors, engine hood and luggage. We ran these on night shift because they created less disruption. Was wondering if using these panels on a racing car was illegal?
Certain other parts were also a "special" run for Ford racing only.
Old 29-03-2025, 11:59 AM   #4
Interceptor
Ahh, makes a lot more sense now.
What class of racing are you competing in?
Old 29-03-2025, 05:31 PM   #5
daryle
Old drag racer
To be more specific i am pretty sure we also made aluminum door inners for the coupe range of falcons as well. Type of racing was Aus touring cars back in the early 80's.
Conrods were typically called "Moffat" rods and were a real pain on tooling because of the high nickel content. Normal 351 rods hit with a hammer would go clunk, Moffat rods hit with a hammer would go ping. Supposedly good for another 500 revs at least, polished and shot peened good for another 1000 rpm with upgraded rod bolts. If any of this info may be detrimental in any way i ask the mods to delete it.
We ran the panels on night shift because any aluminum scrap could not be allowed to go onto any scrap conveyor so all scrap chutes etc had to be closed and aluminum scrap manually collected.
6 users like this post:
Old 29-03-2025, 08:47 PM   #6
How did the dies go with aluminium “smearing” onto them in deeper draws? Also what about metal gauge - surely there was adjustment to allow a thicker sheet? Was it a chore to decontaminate for the steel runs afterwards?
Old 30-03-2025, 09:02 AM   #7
daryle
Old drag racer
The inner panels were not very deep draws but we still had lots of problems regarding panel splits. Because they were inner panels some minor splits were accepted. Thickness was about the same as the steel inners at around 0.7mm.
Draw dies were steam cleaned after runs but this was the case when steel was run.
