View Poll Results: What do you think is better on startup
Let it idle till it warms up 115 45.10%
Start moving and drive normally 140 54.90%
Voters: 255. You may not vote on this poll
Old 24-02-2005, 09:23 PM   #31
EFFalcon
Last warning
EFFalcon's Avatar
i start it and thrash the shit out of it...
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 24-02-2005, 09:30 PM   #32
Psycho Chicken
Psycho Chicken's Avatar
And wonder why you bend valves :P
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2005, 12:16 AM   #33
Brute33
Boss 350
Brute33's Avatar
Originally Posted by SSbaby
Definitely drive off soon after startup as the cats heat up quicker to allow the engine's PCM into closed loop operation sooner. But keep it under 2000rpm until all fluids are up to operating temps.
Better for the car and environment. But each to their own...
Not true ..
Closed loop operation happens at idle and cruising only , as the ECU is receiving the oxygen sensor/s feedback which in turn keeps the A/F ratio at around 14 to 15 : 1 which is around optimum for the cats to clean the exhaust gases.
Open loop is used for anything else , which is where the mapping comes into play.
As for warming up . Start for 30 secs with a few light revs , then take off.
Brute33 is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2005, 01:40 AM   #34
SSbaby
SSbaby's Avatar
Originally Posted by Brute33
Not true ..
I beg to differ. O2 sensors don't work until they're heated up to around 330C degrees. That's the physics and chemistry part of it out of the way!
As for open loop, it is usually engaged at power enrichment mode which most of the time is WOT but not necessarily.
As for 14.7... that's stoich and that occurs when the mixture is nearly 15 parts of air to one part fuel ... which is normally at cruise (i.e. when the economy is best).
You sound like you think you know what you are talking about. I will counter your argument with solid evidence if you still disagree. ;)
BTW, the cats don't like constant periods at idle especially at cold start as the mixture is very rich and not good for the cats... that's why manufacturers these days move the cats closer to the engine - for faster heating of the O2s and quicker response time in closed loop.
SSbaby is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2005, 01:56 AM   #35
needturbo6
ooga-lagga-ligga-lagga
needturbo6's Avatar
my 4L EB stays in closed loop to a certain amount of load which is nearly always up hills and up to about 10-20% throttle on flats.
and 14:7.1 is the optimum ratio for the mixture to get burnt completly
needturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2005, 02:48 AM   #36
lv619
lv619's Avatar
Haha, i just jump in and drive. I'm usually always late for something, so theirs no time for warming up my car, lol.
Me fail English? That's unpossible.
lv619 is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2005, 09:21 AM   #37
big_waity
Windsor Man!
big_waity's Avatar
Car engines are not stationary engines, they are designed to carry a load. The best way to warm an engine up is to start it, then drive straight away, but gently. You need to put a load on the engine from the moment it starts. However, you also need to get oil all over the inside. So, just start it up, then take off and drive around gently until it is up to running temp, then, don't you dare let it drop below redline :P
big_waity is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2005, 10:21 AM   #38
Kenaz
Kenaz's Avatar
I start driving pretty much straight away and take it easy for the first 15 mins. My old EA used to cop a flogging, I'd jump in and with no mechanical sympathy start thrashing it before the temp needle had even moved. Now my bro's car it's done about 400,000 and still going strong. Built Ford Tough eh?
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2005, 11:32 AM   #39
FordFan86
meow
FordFan86's Avatar
Just thought i'd add my 2c... 14.7 is the stoichmetric ratio required for complete combustion, ie.. pure oxygen + fuel (some big carbon chain), this is not the case for cars as AIR does not contain 100% pure oxygen, this is why cats are required to filter out the N and C compounds which are a result of incomplete combustion.
FordFan86 is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2005, 11:48 AM   #40
SSbaby
SSbaby's Avatar
OT:
On the GM PCMs you used to have what's called a lean cruise feature until the EPA stamped it out - the AFRs were as high as 17:1- this feature was omitted on US vehicles due to their tougher emission laws.
BTW, for maximum torque, the AFRs should be around 11.2:1 while for max power, around 12.8:1 but it does vary slightly between engines.
Old 25-02-2005, 06:57 PM   #41
Timmeh
Fairmont Ghia
Timmeh's Avatar
Originally Posted by smciner1
The GT I have to let warm up, it usually takes about 3 - 5 minutes before it decides it wants to idle by itself.
My RS2000 has the same characteristics, you'd need three feet to drive it if it is to be driven cold. But that doesn't happen, you just need to be patient heh.
Tim
Timmeh is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2005, 07:01 PM   #42
XplosiveR6
Viper FG XR6 Turbo
XplosiveR6's Avatar
ow, poor car, gets no lovin
XplosiveR6 is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2005, 12:46 PM   #43
pepsimax
pepsimax's Avatar
i just start it let it idle for a few seconds while i put the sunnies on and set the phone up then drive as normal,,under normal driving conditions you won't hurt the motor or transmission or the diff as they are built for it,,now if you were to redline it on cold start then you derserve what you get,,,a slap up the side of ya ed,
NO ONE DIES A VIRGIN AS THE WORLD SCREWS US ALL :thebirds:
pepsimax is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 02:43 AM   #44
Steffo
LPG > You
Steffo's Avatar
I start the car, let it warm up, then drive off. Keep it a bit light for a while until the gearbox, diff etc warms up.
LPG Lovers Association President & Member #1.
Steffo is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 07:39 AM   #45
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
Location: on my p.c now with internet! ok i'll still use works internet too.
I start it let it idle for about 30sec than drive off slowly till it warn up.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 08:45 AM   #46
Dilan
Dilan's Avatar
My manual warns me not to let it warm up for more than 20-30 seconds.
Dilan is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 08:50 AM   #47
Falcon Freak
Falcon Freak's Avatar
I usually let the car idle for 30 seconds before I start to drive. This is not enough to warm up the car but is enough time to allow 'everything to settle'. Once on the road I don't start giving the car stick until it reaches normal operating temperature.
FF
Falcon Freak is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 09:33 AM   #48
protd
TUFF FORDS
protd's Avatar
it depends on the car the xr8 just start and go.. but the cortina with its forged pistons and agressive cam you'd be mad not to let the engine warm up before driving/racing
protd is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 09:40 AM   #49
HLC
Audi S3
i just drive.
Old 15-09-2006, 10:32 AM   #50
LTDHO
The one and only
LTDHO's Avatar
I thought this thread died in Feb
Tuned by CVE Performance
Old 15-09-2006, 10:33 AM   #51
johnydep
johnydep's Avatar
Start it up and drive, that's the best way to get all parts of the engine warmed up as well as the drive train.
Long idling only warms some parts of the motor and nothing else, giving a false impression that the vehicle is ready for anything.
The Territory section had a similar poll awhile back; Do you warm up your Tezz?
One important thing to note is engine oil viscosity, thinner oil is better for cold weather start up.
The true danger only occurs when you take a potentially dangerous piece of machinery
and place it in the hands of the most unpredictable species on the planet.
Human behaviour, as history has catalogued, cannot account for what any persons actions may be,
especially concerning their love of the motor vehicle.
http://www.fireservicecollege.ac.uk
johnydep is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 10:56 AM   #52
Genghis
It's Clobberin' Time!
Genghis's Avatar
I start it up, buckle up, mirrors etc and then I'm away. Not to much in the way of warm up really.
Owner/Driver of:
2009 Velvet FG G6E
Former Fords:
2003 Blood Orange BA XR8
1993 Winter White XG S Ute
Genghis is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 12:32 PM   #53
boogernissan
feza
boogernissan's Avatar
i have an ea spac sedan 4sp auto,i wait for oil pressure to go up and lifters to quieten down,there a bit noisy on start up then cruise off normally,no real warm up period at all.i wait a bit before i start givin it a hard time,dont really cain it though cos its a gutless auto.need to put my t5 in it
boogernissan is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 12:37 PM   #54
Hardtopxb
Once PHASED.
I just wait until my oil pressure reaches normal specs, then drive the car normally..
2006 BF XR8 Bionic.
Hardtopxb is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 02:00 PM   #55
DODDO
Can man
DODDO's Avatar
I start it up and go lok the house up, which takes about 3 mins or so. Then put it in gear and off we go.
I dont give it a hard time though, just low revs till its warmed up, then i drive it normally after that.
: HSV tools-made for HSV fools :
:2007 PJ Ranger duel cab 4X4:
DODDO is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 03:17 PM   #56
MoreHPformyXR6
MoreHPformyXR6's Avatar
Originally Posted by XplosiveR6
oil pressure takes a whole 3 seconds to build up so that should not be a concern, i always just drive my car easy untill it gets to full operating temperature, the quicker it gets up to temperature the less wear on the engine.
I do same. I dont usually drive my car hard at all. But if I ever do its always after it's warmed up.
FGX XR6 Lightning Strike Sedan
BA XR6 Mk II Shockwave Sedan - Now Sold - gone but not forgotten
mods: 20% under drive, Pacemaker Comps 4495' (ceramic coated) , 3' Metal Cat, XR6T exhaust - twin 3' tips, F6 CAI, K&N panel filter, PWR trans cooler, customed tuned by Heinrich Performance Tuning HPT 183.7rwkw.
Originally Posted by ATMO SIX
You have become the new SLOANY mate, no real quality to your current post(s).
MoreHPformyXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 03:34 PM   #57
Kryton
Kryton's Avatar
todays car guide said the best way to warm up a car is to start it and then drive it straight away.
Old 15-09-2006, 03:55 PM   #58
Ryan
With the VL, I just start it up and let it idle over for a couple of minutes.
I've had to do it, because sometimes on start up it's misfires a bit and chugs.
It's brilliant, after it's warmed up though..
Ryan is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 04:09 PM   #59
Joes_meat
Churches Eat Souls
I usually give it about a minute. Then I don't exceed 2,000 rpm until full operating temperature.
Joes_meat is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 08:15 PM   #60
99FalconS
99FalconS
99FalconS's Avatar
Get moving straight away but dont stress the engine let warm up.
Most thinf=gs i have read say that you dont need to let it idle and that it just a good way to waste fuel.
99FalconS is offline   Reply With Quote Multi-Quote with this Post
